Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Red p plater looking to upgrade brakes
    VT calais 1999
    Jun 2009
    Gympie
    Default Red p plater looking to upgrade brakes
    throught that would get ur attenion lol basiclly i am a read p plater with a modded commie and i was talking to the guy that mods the car for me and said your next mod should be the brakes. and i tottally agree with him even if with upgraed breaks i only stop 1-3m eailer that could still mean saving a life so yeah so i am just after a lil info on it
    i currently own a vt Calais 1999
    nil
    Dec 2009
    Well I am unsure on the set up of a vt calais but the options are basically all the same.
    Bigger, better rotors, slotted possible x drilled.
    Better pads to suit your driving, and pre-mentioned mod's.
    If its running single piston calipers, consider dual piston or even quad piston calipers, which will in turn require a better master cylinder to apply the req. pressure.
    MX83
    Jul 2008
    hills area, sydney
    You would probably best be going with the VE conversion for the front. Don;t worry too much about the back, maybe just slotted discs and some good quality pads.
    Edit: WTF, why don;t you mod your own car?
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
    VT calais 1999
    Jun 2009
    Gympie
    just basic mods exhaust extractor highflo cat throught to tip cold air intake kn pannel filter and sl king springs all round
    i dont have a lot of cash so whats the ceapest way to get my breaks working better?
    VT calais 1999
    Jun 2009
    Gympie
    because i am not a mechanic or anything like tha i am a baker mate and who cares if i do the mods on my car if u have nothing productive to say then kindly pi$$ off
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    The VT's have decent brakes, just get some decent pads, flush the fluid if it's old, replace the rotors if they are on their way out. Most people would go slotted in the process.
    You can run off and spend $4,000 on a "big brake" kit which you don't need and all you'll be doing is locking the wheels up every time you step on the pedals because you'll need racing slicks to keep up with the callipers.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    MX83
    Jul 2008
    hills area, sydney
    Quote Originally Posted by holden_calais_VT_1999 View Post
    Ahahah your bloody kidding aren't you?!?!
    I gave you my answer which is most likely the right answer for your needs/budget. Please don't think you need to be a mechanic to have some intelligence towards modding a car, you are very wrong there.
    The current modifications on your car wouldn't need an upgrade of brakes because it isn't giving that much more power than stock, but obviously it isn't a bad thing to have some decent pulling power behind the wheels. If this answer has been to harsh for you, please 'pi$$ off' and find another forum, preferbly one that teaches basic english spelling/grammar.
    JCCC NSW
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Yeah dude, go easy you got given good info and now youre telling people to piss off. Having that attitude will get you banned. so just be friendly.
    The Black Beauty
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Here's my 2c worth.. you own a VT, you don't really need to significantly upgrade the brakes with the mods you have so far. I'd look into getting some slotted rotors the same size that yours are now, direct replacements for your current ones. If you are pressed for cash you can just do the fronts for a significant gain over stock, or you could do all 4 if you want to (or if they are getting worn anyway). This way you don't need to upgrade calipers, master cylinder, etc. Obviously do your pads at the same time. Personally I use Bendix General CT as they don't need to be at 1,000,000 degrees to work properly, so they are nicely suited to my car and driving style.
    Read up on cross drilled and slotted rotors. I run them on my car, but some people say they crack if you are not gentle with them. I have had no problems with this myself but if you do your own research there you will be able to make an educated decision. They aren't generally that much more expensive than slotted in the same size.
    Hope that helps
    Sam
    WTB: mulberry VN interior parts
    danja's Avatar
    Jan 2006
    Also, if you go bigger pads you'll be forking out a lot more money every time you change them. Try asking one of the forum sponsors how much standard pad replacement versus say the HSV premium brake pad replacements. Make sure you're sitting down.
    VX Executive
    Feb 2009
    Here is a way to save lives. Drive slower and keep an eye out. anyways stock brakes have plenty enough stopping power.
    1 VX Acclaim
    1000's of possibilities
    VT 2
    Nov 2008
    Heres the facts Jack.
    VT Brakes have a single 1.5" Diameter (i think..) front pot in each caliper. This is effective, but leads to poor brake feel.
    I have - replaced my front rotors with Slotted ones, to aid rotor cooling, and it also wears the brake pad away a little more, presenting a closer to pefect friction pad surface. The material in aftermarket rotors to me feels better as well. I got mine from greg at GSL.
    Pads - the Police Spec pads have a larger friction surface. Improves stopping distance. the material is a more consistent performer as well, so you get a double boost. Again GSL supplied mine.
    Factory rubber hoses seem to be fine. wider tyres and a rear camber kit will also help, as they give you a bigger contact patch on the ground.
    I am keenly looking at the VE larger rotor package greg has.
    As for those that say the VT needs no upgrade ? Bullsh*t. Well - maybe not total Bullshi* but the factory VT brakes are not as good as a BMW, or even some tractors I've driven. VT brakes are put on older model commodores becuase by and large, the older brakes are worse again. The VT is heavier and responds really well to brake upgrades, and i wholeheartedly advise everyone to spend more on brakes ! They can save your life, your passengers, and whoever you didn't hit's life !
    The only things topping me upgrading to a VE package is budget.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Tsunamix View Post
    Some cars have better brakes than those listed, too, does that mean BMW's brakes are shit and need upgrading? No. They do the job just fine for each model. If you're worried your VT won't stop quick enough, from memory any front brake rotors and calipers from VT-VY(not 100% sure about VZ for some reason) will bolt straight up and provide a strong gain.
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    your on a budget?...slotted discs and EBC red pads fr and rr cost me like $500...the big 330mm/315mm brakes that just landed at me door were just over a G...flush your hydraulics with DOT4 fluid and throw in some Bendix fr and rr and should get heaps of change from $150...
  15. #15
    mrbeef's Avatar
    mrbeef is offline spongiform encephalopathy
    VX2 V8 Calais/VT V8 Exec ex cop
    Dec 2006
    Whangarei, New Zealand and Newman, WA
    As for those that say the VT needs no upgrade ? Bullsh*t. Well - maybe not total Bullshi* but the factory VT brakes are not as good as a BMW, or even some tractors I've driven. .
    lol you can't compare a tractor to a car. most of them are all wet-system Hydraulic and are required pull up large weights. My tractor will stop a dam sight quicker than my calais even at (40kph). 4wheel braking on the drivetrain
    end rant
  16. #16
    VS Calais & vh sl
    Dec 2006
    deception bay
    All VT models are fitted with ventilated discs at the front and solid discs at the rear. The brake calipers are the
    sliding, reaction type, with twin pistons in the front calipers and single in the rear.
    My advice for the mods you have would be to get a complete fluid flush with good quality fluid then put slotted rotors all round with good quality pads. Then if you run out of brakes you should have your license taken off you because your driving beyond legal and safe limits for public roads.
  17. #17
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I recon an up-grade to a better attitude on the road for some red p platers would be the best mod they could do!.........for everybodys safety.
  18. #18
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  19. #19
    VT calais 1999
    Jun 2009
    Gympie
    what everyones deal u were all on ur p's at one stage i was just looking at upgradeing my breaks u have noidea how i drive how good or bad i am all i wanted was a lil info about brakes not everyone personal attack on RED P PLATERS just goes to show how many are quick to judge i hope to god when ur sons or daughters are on there p's everyones give them shit about the way they drive and wearing p plates on there car
    if u have nothing better to do then rip on p platers then kindly PI$$ OFF and as far as i am concerened i am a good drive never been in a crash or ever lost controll of my car and never had a speeding ticket so u all are harssing me on my thread so ill say it agian if u got some info then leave it and i will apperciate it but if u just ripping on p plater then kindly pi$$ off
  20. #20
    danja's Avatar
    Jan 2006
    VT-onwards are all twin-pot fronts, rears are single.
    The brakes are just one part of the system which slows you down, and the system is only as good as the weakest link, which in the case of a street driven VT usually isn't the rotors/calipers, but the rubber on the ground.
    If you can lock the wheels with the stock calipers, then how are bigger brakes going to help you slow down? Sure you might achieve the same braking force with less pedal effort, but this does not mean you'll slow down any faster.
    If you were planning to track your car and therefore expected to be doing high speed stops frequently, sure having big brakes might help keep the temps manageable, but for a street car it's a moot point.
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    They sure will! Hell, I'll give my kids shit about wearing P plates. Meanwhile however, I hope to God you learn how to spell and use punctuation!! Write proper English!! I'm sick of wading through posts that are full of illiterate scribblings! This is not just addressed to the original poster in this thread, but to every idiot on here who can't work out where the shift key is or how to use a fullstop.
    Quote Originally Posted by danja View Post
    You are completely correct.
    Sam
  22. #22
    VL EXEC
    Aug 2008
    perth wa
    Quote Originally Posted by savage1987 View Post
    Sam
    In response to ur ranting about English skills Sam i fully agree but mine are shit, we're gonna get a generation of illiterate ****s coming through and i honestly blame the schooling system there is more focus on maths and science and aboriginal studies..... then again maybe i just never went to English
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
  23. #23
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by VryNeat View Post
    Now I'm no racist by any stretch of the imagination, but LOL@aboriginal studies..
    You're right, so many deadshits in the coming generations.
    Back on topic, don't upgrade your brakes unless you have money to burn or just really hate brake fade.
    Sam
  24. #24
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Just cause you have never been in a crash, lost control of your car or had a speeding ticket, does not always mean your a good driver. And being on P plates, you have limit driving experience and yet to have it all happen to you. Even after your 60, You will still see new things. Being a bike rider, People of all ages have almost killed me, Lots of times, and just being able to react quick enough has saved me. After 3 years of riding, i gave it up as some people just do not concentrate enough, And that i saw death to much.
    Yes, I am a Green P Plater, I still get caught out while driving. Everyday is a new adventure on the road.
    Good that you want to upgrade your brakes. I Would hate to think how many people that have no pads or discs left on there cars.
  25. #25
    MX83
    Jul 2008
    hills area, sydney
    So I think you have a few options now. Flush the system and put new pads and slotted rotors through to a complete converstion. Now I would go ask your mate what he thinks would be best for you to do
    JCCC NSW
  1. Brakes - choices of upgrade
    By Vt-Brrrlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2009, 06:54 PM
  2. upgrade on brakes
    By djeyecon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2008, 09:27 AM
  3. Brakes Machineing or upgrade?
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 11:30 PM
  4. VT Brakes upgrade on VN SII
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2006, 05:22 PM
  5. Brakes Upgrade
    By executive_power in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2006, 03:16 PM
