Results 1 to 3 of 3
Thread: VT Power Steering Pinion Dust Seal
    VT Commodore
    Dec 2009
    Default VT Power Steering Pinion Dust Seal
    Hey Guys,
    Got v6 VT and it has a power steering leak, From what I can see it is leaking from the pinion dust seal and running down. (See Picture Below - Dust Seal Location)
    Now the Pinion Dust Seal is loose and I can move it around, Are they supposed to sit over tight and stop any leaks? or is there something else internally which the pinion goes into the rack that will do this?
    Anyone dealt with this before?
    If there is a oring internally of the pinion that could be stopped leaking with Lucas Power Steering Stop Leak? or do i just need a new Dust Seal over the top to stop it leaking?
    Or it is something more inside the actual pinion area?
    Jason
    See Picture Below:
    VT Commodore
    Dec 2009
    If this is the pinion seal am I able to disconnect the steering shaft and pull that off, undo the pinion locking nut at the bottom and whatever else is there and remove the pinion? change seal and put all back together?
    All whilst still on the car? Im really not wanting to remove from the car...
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    You pretty much have to remove it from the car, not that hard. Remove the uni joint at the top, the 2 bolts that attach the rack to the k-frame and remove the tie rod ends without adjusting them.
    I hear that seal is the most common to go in this rack, but may be wrong on that as only 1 person has told me this. Mine was not leaking from there when i replaced it.
  1. Help!!!!! Pinion Seal
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2008, 01:17 AM
  2. VS power steering seal replacement
    By sik_fiddy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2007, 10:18 PM
  3. Replacing Pinion Seal
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2007, 03:26 AM
  4. Pinion oil seal
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2006, 01:11 PM
  5. Power Steering Seal
    By vp manual wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2005, 07:57 PM
