Results 1 to 16 of 16
Thread: vt creaky front doors
    2002 vx wagon
    Mar 2009
    Default vt creaky front doors
    I have a VT and the front doors creak when opening and closing.
    It looks like the pin at the pivot point might have play in it .
    Any ideas
    Craig54
    98 VT Berlina
    Nov 2008
    Western Suburbs, Victoria
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    hey i had the same problem and its the little arm with the grooves in it linking the door to body, they become deeper over time, all you have to do is take off door panel and you can reach in undo two or three bolts i think, take it off and get ur grinder and smooth them out a bit.
    VS Calais & vh sl
    Dec 2006
    deception bay
    vt s s1
    Mar 2009
    Check the check strap for tightness.
    This is the black hinge in the middle.
    SHould be 10mm
    airtime2107 is offline STOP. It's Hammer time.
    99 VT Commodore Acclaim
    Nov 2009
    Quote Originally Posted by 180sc View Post
    why not put a little grease in there?
    Agreed; or something similar like silicon spray. Worked for me.
    2002 vx wagon
    Mar 2009
    I tried grease and didnt do any good.
    I think the pins where it pivots are worn and thats why it clicks/creaks.
    I will see if i can get some new ones and try that
    VT COMMODORE
    Dec 2008
    I think there is a plastic washer/grommet that goes into the pin which wears down. I flipped the existing one around, which solved the problem for a few months, then started doing it again. Should only cost a couple of bucks from Holden for new ones
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Wd40.................................
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    2002 vx wagon
    Mar 2009
    replaced the nylon bush ...nope thats not it
    how do I get the check strap out vt series 1????
    VT COMMODORE
    Dec 2008
    Did you try replacing the pin? I am sure the noise is coming from that on mine. I havent had time to look into it as yet though. I cant see the actual check strap making the noise as it sounds like a gripping-then-slipping clunk and the check strap is too smooth to make that sound.
    charged vu ute
    Jan 2010
    boils down to getting it serviced. when serviced, the door hinges and straps should be lubed!! stop this problem in the long term.
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    VL TURBO/ VS 5L STATO/ VP BT1 5L
    Jan 2010
    Quote Originally Posted by nathanwright View Post
    is there a tutorial on here for servicing your doors?
    just get some lube mate and put it in there, pretty simple. but a tutorial would be good.
    (hint hint edals)
    Quote Originally Posted by STEALTHY™ View Post
    Spmething like a VL mototr into a little carolla
  15. #15
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by DERTY View Post
    (hint hint edals)
    lovely comment lol, made me have a bit of a laugh,
    anyway, i had the same problem but it just dissapeared for some strange reason, never heard it again, been nearly 3 months since, (i think...just trying to remmember when i last heard it), but should i try to fix it probably or just leave it the way it is?
  16. #16
    feg
    feg is offline
    VT S S/C
    Jul 2006
    I had this problem with mine, I replaced evertying I could think of around it. The check strap itself, the door striker but the noise continued. Then I noticed one day that the lower bolt was not tight. so I went to tighten it and snapped of the bolt. I took out the top bolt and the check strap fell inside the door. I hear it clunking, around sometimes when I go around a corner now and then. I plan to take the door trim off and try to get a longer bolt through the bottom hole and then will put on two nuts to lock it down. If anyone else finds something that is similar please let me know. or for that matter dissimilar, that fixes it.
    and yes I am sick of my door swinging open, and closing on me when I least expect it.
  1. Vr front speakers in doors
    By calebsnodgrass in forum Car Audio
    Last Post: 13-11-2009, 08:14 PM
  2. 6.5 inch in VX front doors
    By Denno in forum Car Audio
    Last Post: 18-05-2008, 10:39 PM
  3. Front Doors
    By 85_VK_EFI in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2006, 09:40 AM
  4. removing front doors
    By Harro_vt in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-01-2006, 01:41 PM
  5. 4 x 6" in the front doors?
    By vpwgn in forum Car Audio
    Last Post: 29-03-2005, 01:49 AM
