Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: VX Berlina wont start
    VX Berlina
    Dec 2009
    brisbane
    Exclamation VX Berlina wont start
    Hey everybody, my vx berlina wont fire when i go to start it. I had been out and about all day with no proplems at all,
    I tried swapping fuel pump relay, used my spare key, checked leads, now im doing my head in.........
    It will turn over fine, all dash lights fine just wont fire.
    Next step would be greatly apperiated.......... Starter fine, battery fine, half tank fuel,
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Sounds like your Starter Motor or maybe your Starter Solenoid. Wouldn't be your battery or Alternator as its still holding power.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VX Berlina
    Dec 2009
    brisbane
    Not my starter motor, it turns over fine, got alot of power, just not firing,
    What your saying Mumboman is full of shit,
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the security light flashing when you are trying to start it, if so the immobiliser is not turning off.
    MY RIDE
    VX Berlina
    Dec 2009
    brisbane
    If its the security light on radio it is flashing while im turnig it over and i noticed the engine warning light is on...........
    VX Berlina
    Dec 2009
    brisbane
    Quote Originally Posted by accentstencil View Post
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I mean the security light on the mode switch.
    MY RIDE
    VX Berlina
    Dec 2009
    brisbane
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When you turn the ignition on do you hear the fuel pump priming for a few seconds?
    MY RIDE
    VX Berlina
    Dec 2009
    brisbane
    The only thing i notice is the power trans warning light does not go out while its cranking over, unable to hear fuel pump,
    It was running sweet till i went to start it last night,
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    ya should be able to hear ya fuel pump coming on, (not while cranking it over but just as ya turn ignition on and dash lights come up, should hear it then) even if ya get someone esle to turn ya ignition on for ya while ya get down near tank to listen and make sure.
    nil
    Dec 2009
    If you can hear it...hit your fuel tank a couple times with a hammer whilst someone turns the ignition on..if that doesnt work try again with someone cranking it.
    If the fuel pump begins to operate, replace fuel pump.
    Another thing to try if your fuel pump isnt operating is get a battery and two pieces of wire, crimp some connections onto them and put direct power to your fuel pump, see if it operates, if it does, get someone to crank it. If it starts, your not getting power to your fuel pump. Check signals from ecu.
    VX Berlina
    Dec 2009
    brisbane
    Just checked fuel pump and it primes when ignition turns on, Im going to try new leads and plugs maybe that could close the gap a bit more, If that makes no differnce is it possible it could be coil pack
    VX Berlina
    Dec 2009
    brisbane
    Quote Originally Posted by wana s' charge stock vt View Post
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You might want to check your fault codes.
    MY RIDE
  16. #16
    VX Berlina
    Dec 2009
    brisbane
    VX Berlina
    Dec 2009
    brisbane
    VX Berlina
    Dec 2009
    brisbane
    So far it looks like i got codes 46 and 75,
  19. #19
    Sep 2009
    goldcoast
    not sure if you know or not but it says 46 is your crank angle sensor(which would explain y it's not starting)
    and say's 75's auto related
    don't hold me too it , its just what the book say's
  20. #20
    VX Berlina
    Dec 2009
    brisbane
    75 is telling me voltage spike which affects the BCM, unsure about other codes but i keep getting 75
  21. #21
    '04 VY2 SV8
    Oct 2009
    i wouldnt worry about the leads and plugs its more likely to be your coil pack and DFi module.
    or could be the crank angle sensor like wana s' charge stock vt said.
    mate had the same problem with coil pack,parked it up overnight then wouldnt start the next day
  22. #22
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    This is correct. It does sound like the Crank Angle Sensor. Check the plug and wiring at the CAS.
    MY RIDE
  23. #23
    VX Berlina
    Dec 2009
    brisbane
    Thanks guys, this one has been a headach, will let yous know how i get on
  24. #24
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I added an attachment to my last post after I replied, you might not have seen it.
    MY RIDE
  25. #25
    VX Berlina
    Dec 2009
    brisbane
    Thanks for that, big help
LinkBacks (?)
  1. Vl Berlina Just Wont Start. Crank Angle Sensor?
    By yogorilla in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 04:08 PM
  2. VS wont start!
    By Silver_VS_II in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 06:58 PM
  3. engine conked out>VS Berlina wont' start
    By hj to vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 07:31 PM
  4. vs berlina keeps stalling and after driving wont start
    By spaceman69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2008, 02:45 PM
  5. vc - wont start
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 04:35 PM
