Results 1 to 9 of 9
Thread: seatbelt not retracting
    kazalex's Avatar
    kazalex is offline karen
    red vx series 2 commodore
    Oct 2008
    adelaide
    Default seatbelt not retracting
    hi,i have a vx commodore series 2 and my drivers seat belt won't retract properly,i have got it stuck in the door once or twice.
    any ideas please
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    New seat belt, not hard to replace. Don't risk your safety to save a bit of coin. Can't remember price from Holden but it wasn't expensive.
    Ronald Reagan (1986)
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    VT Executive
    Aug 2007
    Timaru, NZ.
    Adjust the tentioner. clean off what ever crap is on the beat at the top where the belt comes down onto your lap and try a little dry glide. Worked for my old Subarus.
    VX Berlina
    Apr 2007
    If you get one of those then prepare to get your car defected.
    1. It doesn't retract
    2. No seat belt pretensioners
    3. Where would you put the anchoring bolts
    4. It wouldn't work with a stock seat.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by acarmody View Post
    Yeah As i thought. Just thought i would post for fun. I Use to ride bikes that have no seat belts and no metal around you lol
    Calais VT
    Apr 2011
    Masterton, New Zealand
    Its been ages since this thread began but still relavent as I spent a lot of time going thru heaps of post, threads to fix a broken-slow retracting belt. All the info was great and it pointed me in the right direction, so I have a couple of points to add that would have saved me $130. Still the lesson has been learnt and here it is
    1. After you have stripped the pillar of all trim, first do a little test - pull the belt just above the retracting mechanism. If it retracts quick and it should do then you know it can be fixed.
    2. The problem is other parts that the belt touches are hindering the speed of retracting.
    3. I followed instruction to wash the belt put it back on and still slow retracting so I brought a good 2nd hand belt and same slow retracting.
    4. Followed one more step and sprayed the belt and everything that it touched with silicon based spray - moved better but still not to my liking
    5. The problem I found is where the belt goes through the large buckle attached to the pillar. It has to be in line with the natural movement of the belt, If the buckle is at an angle then the belt will not move freely. Once alined properly it will move very quick.
    Did I need to get another belt? NOOOOO bugger it. The old belt worked once I moved the buckle so the belt moved freely, with a little spray of silicone, so Im selling the one I brought,
    And just a little thought for the day. "Dont fix your car angry ...... ,a lot of plastic trim is very brittle and easily snapped" LOL
    VX Spac
    Jun 2009
    if it's the seatbelt in the backseat, it's the reel of the belt that's broken for sure if it doesn't retract properly. try to remove the plastic trim on the side and remove the nut of the belt reel, and then you pull the belt all the way for you to see the plastic reel then inspect it. the plastic reel looks so brittle and easy to break. mine's broken both left and right rear, but i got a pair from the wrecker and changed it. all good now.
    1998 HSV VT GTS 5.7 Stroker
    Mar 2010
    Tauranga NZ
    There's a good chance that theres a twist in the webbing behind the trim panel,so just untwist it.second thing it could be is a buildup of dirt under the top hanger where the webbing goes though.clean off and spray it with a silicon spray.
  1. VS Seatbelt
    By Bel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2008, 09:14 PM
  2. Seatbelt buckles
    By undar8ed1 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-09-2008, 12:26 PM
  3. Retracting an ebay bid, WTF...
    By undar8ed1 in forum The Pub
    Last Post: 22-08-2008, 01:13 AM
  4. seatbelt specs
    By whitevrboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 10:20 PM
  5. Seatbelt
    By Not_An_Abba_Fan in forum The Pub
    Last Post: 27-02-2008, 08:50 AM
