Results 1 to 25 of 25
Thread: Limp home mode. urgent help needed!!!
    VX Executive
    Feb 2009
    Default Limp home mode. urgent help needed!!!
    ok heres the story.
    on my way home from work driving sensibly along rural roads and came upto a t intersection so i slowed down. looked to my right coz i was turning left and saw a car about 100m down the road and decided to go for it. put my foot about 3/4 on the accelerator, got a bit of power then it seemed to have gone into limp home mode where the car will get home but wont accelerate very fast. i think. i pulled straight over thinking something blew. opened bonnet. nothing apeared disconnected or blown. engine was running fine. not overheating at all.
    any bright ideas on the case? please this is urgent.
    1 VX Acclaim
    1000's of possibilities
    VX Executive
    Feb 2009
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    Oddd, Maybe try disconnecting the battery for a min to reset the computer, give it another try.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    4.2 vt executive
    Aug 2009
    VX Executive
    Feb 2009
    Ok just tried battery. Nothing new. Perhaps it's gear box or diff?
    1 VX Acclaim
    VX Executive
    Feb 2009
    Feels as if when accelerating the breaks are also applied. Maybe torque converter?
    1 VX Acclaim
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Does it do it all the time, if so it could be your leads
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VX Executive
    Feb 2009
    Just started today. Everytime I accelerate over a quarter throttle.
    1 VX Acclaim
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Vx Calais LS1 / Ve Berlina V6
    Mar 2005
    VS Calais & vh sl
    Dec 2006
    deception bay
    check error codes. mine done this and turned out to be 1-2 shift solenoid in the auto but in saying that it could be anything so check ya codes.
    VY SII HBD Calais L67
    Dec 2006
    VX Executive
    Feb 2009
    ok was driving again and now i get barely any throttle and then rpm went to 0 while driving. fuel pump?
    i'll try error codes when i can.
    1 VX Acclaim
    VX Executive
    Feb 2009
    Ok.. after a bit of research i now believe its not limp home mode as i can still travel at 100km/h..
    just seems that when it revs over 3500 it slips into neutral and goes no where. just slows down until you take foot off pedal and put it back on. almost certain its something to do with the fuel line.
    1 VX Acclaim
    2000 Vx Berlina
    Nov 2009
    Melbourne Victoria
    100% its the fuel pump man.. happened to three cars of mine.. all vt/vx... changed the pump fixed the problem
  15. #15
    VX Executive
    Feb 2009
    cheers. its at mechanics now and thats what they think.
    1 VX Acclaim
  16. #16
    2000 Vx Berlina
    Nov 2009
    Melbourne Victoria
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Just a thought, it's not the 'traction control' playing up?......(de-tunes motor so it's got no guts).
  18. #18
    VS Calais & vh sl
    Dec 2006
    deception bay
    for future reference limp home mode you can still do 100kph its will just have no 4th or overdrive and depending on car no 1st or no 2nd.
  19. #19
    VX Executive
    Feb 2009
    Had all gears. traction was what i was thinking because i do accidently leave traction control on a fair bit. and you know, trying to get around a corner quickly upsets it.
    1 VX Acclaim
  20. #20
    VT wagon
    Nov 2009
    I got a simular issue with my VT wagon. Only changing from 2nd to 3rd it seems to go into netural? its like the gear box changes too slow. Also the car will not kick down in any gear? And I have already changed the auto and still doing the same thing???
  21. #21
    VX Executive
    Feb 2009
    I'd say yours sounds more like the solenoid problem or something. i just bought nasty dirty fuel and it wore out the pump. whens the last time you change your fuel filter/pump?
    1 VX Acclaim
  22. #22
    VT wagon
    Nov 2009
    Hi Maxseverity,
    I just got the car not long ago and not sure if the fuel pump has been changed at all? I doubt it.
    Did your also not kick down into any gears? And did the CPU give you a code for the fuel pump?
  23. #23
    VX Executive
    Feb 2009
    i didnt end up checking codes. my car if i did manually change down gears (auto) would either stall or there'd be no acceleration because the fuel pump couldnt push through all the crud built up in the fuel filter.
    1 VX Acclaim
  24. #24
    VT wagon
    Nov 2009
    Yeah my car does'nt stall just the auto is doing its own thing lolz but i'll change the fuel filter
  25. #25
    vt 1999
    Dec 2008
    check the wire of gas pedal it may be stick some where this thing happened to me and ended with the wire
  1. Limp home mode.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2012, 04:32 PM
  2. What can cause 'limp home mode'???
    By meanvrss5.0l in forum V8 Development and Modification
    Last Post: 28-11-2010, 09:03 PM
  3. Limp Home Mode
    By crazybiker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2008, 08:22 PM
  4. limp home mode
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-07-2006, 04:56 AM
  5. limp home mode
    Last Post: 24-11-2005, 09:17 AM
