Results 1 to 7 of 7
Thread: sensor next to oil filter leaking oil!
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    Default sensor next to oil filter leaking oil!
    Hi i just noticed when i was underneath my car that the little sensor next to the oil filter is leaking oil, has anyone else had this problem? and what is the sensor called? it has started to use a bit of oil lately but i think that might be another problem with oil in the cooling system.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Oil pressure sensor.
    Double check its leaking, sometimes when you take the oil filter off its easy to spill oil over it.
    Simple to unbolt, and bolt new one in and connect the loom during your next service (save draining the oil for no reason)
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by johnno010684 View Post
    I'd clean off the oil and chack again in a day or 2 to make sure it is leaking, but in saying that my old wagon leaked from that spot too
    Quote Originally Posted by Tom_1569 View Post
    why would it be required to drain the oil to change it?
    Power is measured in DECIBEL
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by vn6pwr View Post
    Its not, but unless your really quick, its going to lose some oil, easier just to do it at next service when the oil has been drained.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    I wouldnt think any oil would drain out. should have all drained back into the sump and whats in the oil filter. but yeh i wouldn't worry about waiting till next oil change to replace it.
    Also not to be picky but pretty sure its an oil pressure switch, not sensor
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Thats a really good point, I've only ever done them during a service, and was once told they leak if you remove them without draining the oil, but never thought more about it then that.
    Yes its a "switch" not a "sensor" in the case of Ecotechs.
    VY SII HBD Calais L67
    Dec 2006
    I did mine a couple of days ago when the car was cold. Sump was full to the dipstick and I lost only about 20mls of oil from the oil pressure sensor port. Tridon part number is TPS064 and they retail for around $60. Don't forget some thread sealant or teflon tape when you do it up
    VYII Calais L67
  1. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  2. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  3. A Leaking Oil Filter
    By burnsy150 in forum General
    Last Post: 11-10-2008, 08:33 PM
  4. air filter/box sensor thingy
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2006, 02:21 PM
  5. Leaking from speed sensor
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2005, 01:55 PM
