can anyone recommend a good place to supply and fit a 4 point camber kit in a vx berlina.
has to be in the western suburbs of victoria thou haha. ive heard of a couple places but im not sure where to go
cheers
I personally prefer to take my car to Pedders for all suspension and steering work as that is what they speciaise in. Won't comment on anything else but the fact that above all, they know what they are doing when it comes to your suspension.
Now, that seemed to be a bit of a puff piece for pedders, so i'll say like most other mechanics etc. They still might try to rip you off for some things.
Have you considered fitting the kit yourself and then taking it to pedders or somehwere else for the front and rear (both must be done when rear is done). With VT - VZ's it is a difficult Trailing arm to remove, as the bolts on the outer are difficult to remove due to clearance issues, so I found that the labour charge could be a bit more inflated because of this?
I'm not sure on that though as I haven't seen quotes for other cars...
yeah i considered doing it myself.. i just helped one of my mates put a camber kit in his car... took wayyyyyy to long and it was a lot of hassle... i just want to drive in and drive out. job done heres your money lol
they would only do a two point kit saying a four point was going overboard. just wondering if there was any aftermarket place that does it
peddars will do the job and a good one at that.. but they will try and rob you for all you are worth, literally
yeah pedders qouted me $600 for a 2 point one... i think thats way too steep
I can supply a 4 point Super Pro kit for $165.
Same polyurethane material in the bushes. The adjustment method may be different, but with a lot of products, you pay a premium for certain brands just because of the name.
Cheers for the help guys
yeah i heard there were different types of camber kits too which one is the best? cause if i wanna do the job i wanna do it properly haha
tyre pro's in sunshine oppisite western market....i recently got mine done supplied and fitted for $395
Or if you can dump a VX2-VZ irs in it, i bought the IRS from some guy on eBay for cheap and mechanic cost 290 for him to fit it.
yeah ive been told to do that too lol....... vz irs.. would be an update too tru
oh yeah and ill give the place in sunshine a ring... thanks HSTL3R
