Results 1 to 4 of 4
Thread: vt sump gasket
    98 VT 3.8 auto
    Oct 2009
    Default vt sump gasket
    Can a vt v6 sump gasket be changed, without removing the engine from the vehicle?
    If so what has to be moved/removed to do the job?
    Vt Berlina 1998 Not my dp
    Jun 2009
    Frankston
    +1 on this question
    Quote Originally Posted by Cobez View Post
    You sir, are as gay as aids and as camp as a row of tents. You also fail..
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    brace the engine and undo the rack and move it back then drop the crossmember down , no need to remove the crossmember .
    VN commodore
    Jan 2010
    Default 1989 vn commodore
    i need to replace the timing cover gasket and sump seal by droping the crossmember down a bit and bracing the engine just wondering if anyone could give me some detailed instrustions on removing the timing cover and crossmember thanx..
  1. Sump gasket
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2010, 01:36 AM
  2. vr sump gasket
    By jasonvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 07:30 PM
  3. vs v6 sump gasket removal
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 07:30 PM
  4. sump gasket
    By CANYONERO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2006, 08:31 PM
  5. Sump Gasket
    By sunriseoversea in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 05:52 PM
