Results 1 to 7 of 7
Thread: 1 foglight does work... the other doesnt?? Help
    2002 II Commodore Vx-S
    Jun 2009
    Default 1 foglight does work... the other doesnt?? Help
    My vx-s series 2 has genuine holden ss foglights installed and the previous owner hardwired them to the parkers.. i know this isnt the way its supposed to b wired but i cbf running the foggies to their own switch just yet. I only noticed the other day that 1 of my fog lights arent working.. I check fuses/globe and nothing seems to b wrong there.. but my parker lights are working just fine.. Im guessing its the wiring somewhere.
    Help please
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    yeah well i would just start from the back of the broken fog light and trace my way with its cable up until it connects to the parker its on.
    It's probs bound to be a stuffed cable.
    The whole 'wiring the fog lights up to the parker lights' sounds a bit dodge to me ahah
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
    00 SS M6/79 chev Monza
    Mar 2005
    wiring the fog lights to the parker is the correct way to do then as the lower the light is to the road the better it is to see through the fog .............however the law states that you must not drive around with your fog lights on unless there is fog ,therefore it MUST be run off of a separate switch
    Get a simple test light (a globe with 2 wires soldered on is good enough ) however a cheap one can be bought from a spare parts place for under $10
    turn parkers on ,earth your test light and touch your positive on the wire of the light that does not work
    just because the globe looks ok it it not always the case ( I replaced one of mine today ....looked fine however did not work ),
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by ausrs View Post
    umm... foglights MUST be wired highbeam only. and they can be used in any inclement weather that lowers visability, not just fog. that's why these days they are commonly also known as driving lights. but if a copper sees foggies/driving lights on when you only got parkers on... you'll be stuffed. i'm 100% sure on this. foggies definitely not wired on parkers... they would even knock you back on next pink slip (if the guy even checks that is).
    but definitely follow ausrs test tips. test actual globe- just because its 'looks' right doesnt mean it is.
    an easier first test would be to swap over globes left to right. if the globe is the problem, you'll know straight away. if both no longer work, you know its wiring.
    Mar 2005
    Quote Originally Posted by UFO View Post
    umm... foglights MUST be wired highbeam only..
    VT factory SS foglights ARE wired in to parkers !
    white foglights are NOT driving lights ,driving lights are by law wired in to high beam and must also have a separate switch
    UFO's Avatar
    UFO
    Oct 2009
    learn something new every day! i always thought foglights were yellow, because white light doesnt go through fog very well. doing a little google search and there's actually quite a few studies that show light colour makes no difference- it's actually the pattern on the lens. my bad... it's just that I see so many VT's with white 'fog' lights, I thought they were driving lights.
    Mar 2005
    try living in Wollongong and driving to Sydney up the mountain .......fog is a fact of life !
    I used to think fog lights were all yellow as well ,high beam and fog just do not mix ,it just reflects off of the fog and you see even less
    the way most manufacturers mount the fog lights (very low on the car ) and with a very narrow beam of light (reflector) it actually gets below the fog ..that's what i think anyway .....whatever it is it works well !
    as far as driving around with them on ..............there are many many idiots out there
  1. VP Speedo doesnt work then works!!
    By bladerunnerkim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 12:48 AM
  2. engine just doesnt want to work.......
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 05:51 PM
  3. brand new key doesnt work. help plz!!!
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2006, 07:29 PM
  4. steering lock doesnt work
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 07:23 PM
  5. Ignition randomly doesnt work
    By Trewman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2005, 07:38 PM
