Results 1 to 9 of 9
Thread: Is this for Real??? Dishwashing liquid to rid of Oil????
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Default Is this for Real??? Dishwashing liquid to rid of Oil????
    My trans cooler lines cracked and i had oil in my radiator. Got a new radiator flushed a few times but there was still oil in the radiator so i did search on Google to see whats the best way to get rid of oil from the cooling system.
    The answers amazed me
    It said to use dishwashing liquid and run it for 100 K's or so and flush it well...
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    scbh81's Avatar
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by edals View Post
    Well you can try, but usalley it will make bubbles as it should lol
    but wont it F*** up the system?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    WHY?........... what do you think will happen?
    Dish washing liquid is pretty mild detergent. Or use hair shampoo, even less caustic as it doesn't even burn your eyes.
    scbh81's Avatar
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by pablo View Post
    Oh ok.. I just thought that foreign substance in the cooling system will have some affect on the seals, water pump gaskets etc....
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Dishwashing liquid should sort the oil problem, you could be right about the water pump seal tho, those things can be pretty sensitive.
    May 2006
    Those cooling bsystems run 50% glycol, it will take the paint off your panels, pump seals are a lot tougher than you think. They were made of ceramic once, probably still are.
    I can see you don't help your mum with the dishes!...LOL
    scbh81's Avatar
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Cheers guys, makes sense now.... I will still try just water flush and failing which i will use Morning Fresh as i know that it works a treat with my greasy dishes!!!!!!
    yeah i do my own dishes mate :-)
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    a little leftover oil isnt going to hurt anything but frothed up suds will cause air pockets and dishwashing liquid is salty so i wouldnt be putting any in
  1. Liquid LPG injection
    By pk2k78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-04-2009, 09:55 PM
  2. New G8 GT - Liquid Red
    By Screw991le in forum VE - WM
    Last Post: 09-01-2009, 11:48 AM
  3. Replies: 9
    Last Post: 10-08-2008, 11:48 AM
  4. Going liquid LPG injection.
    Last Post: 08-05-2008, 08:51 PM
  5. REAL real estate!!!!
    By The1985divo in forum Jokes/Humour
    Last Post: 09-09-2004, 07:24 PM
