Results 1 to 10 of 10
Thread: Where is the water going
    2002 vx wagon
    Mar 2009
    Default Where is the water going
    I have a vx and it seems to be going through a lot of water.
    It runs on gas and the oil is still clear after 8K and there is no white stuff under the filler cap so its not a head or a head gasket.
    Any ideas.
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    do a presssure test and check all the hose fittings? Check the resevior to check there is no leaks... Check the radiator for leaks...
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    check the vapour line for signs of water entering the engine thru the gas system
    Vu Spac Ute
    Mar 2009
    Nazza Wazza North
    check that the Actual mixer isnt leaking,
    "your gayer than a treeful of monkeys on nitrous oxide"
    Statistics show that 90% of all commodore accidents happen right after the words "Watch this bro!"
    vt berlina series 1
    Sep 2008
    check your heater tap, and your radiator tanks for cracks around the brackets that hold the fan setup , use a torch and look for stains
    2002 vx wagon
    Mar 2009
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Have a look under the bonnet at your heater tap . They get brittle with age , happened to mine it was using heaps of water and i grabbed the heater tap and gave it a gentle pull and it snapped off .
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    also check water pump, mine went, started losing small amounts , it would just vaporise, then it finally went, and then u could see the fluid running down front of engine
    WH Grange Gen3, VR V6 Commodore
    Mar 2005
    Happy Valley, SA
    Had a similar problem, VR V6 on gas, turned out it needed a new radiator cap, even though the one on it looked in good condition.
  1. VX leaking water but water tep guage shows normal ???
    By FIN990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 12:51 PM
  2. water in oil
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2009, 08:10 AM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Run your car on water?
    By commodore2004 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2008, 06:08 PM
  5. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
