Results 1 to 5 of 5
Thread: Vt over heating.
    VT Acclaim
    Oct 2008
    Default Vt over heating.
    With the hot weather around combned with stop start city traffic my vt 6cyl is starting to heat up. I've replaced the hoses, fully flushed the system with fresh coolant, all fluids are up to date. I've also changed the thermostat and gasket.
    My fans seem to be switching on.
    What options do I hve? New radiator? Twin fans?
    VS Calais & vh sl
    Dec 2006
    deception bay
    It should have twin fans on it. when cold run it untill fans come on to make sure they are working fine if so make sure you have bled the cooling system properly as to make sure it doesnt have an air lock or the like. failing that check if it has any error codes coming up for possible sensor failure failing even that take it to a radiator shop and make get them to check it out for possible blocked radiator.
    vt berlina series 1
    Sep 2008
    sounds like you need the radiator taken out ,and cleaned out , you wont remove all the crap that sticks in the tubes by just changing the coolant , if you take it out urself and take it to a radiator shop itll save you a few bob
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Also check out your cars running temp in the trip display. If it's above 105 deg with no fans and only going up, you are in it.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Make sure you change your heater taps whilst your puting on new hoses etc etc.
  1. VT over heating
    By rjsimmo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2010, 09:38 PM
  2. No heating
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 12:29 AM
  3. car is over heating.... but not?
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2006, 11:09 PM
  4. heating
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 08:31 PM
  5. VS heating up...
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2004, 10:07 AM
