Results 1 to 4 of 4
Thread: VT berlina fan issuie
    VT Berlina
    Mar 2006
    Default VT berlina fan issuie
    Hey guys, my fan is all screwed up, the air will only come out of the top vents near the windscreen, even if i out it on feet or whatever sometimes if i turn on the cruise control and such it will change the flow to something else but then return to the windscreen vents, any ideas with what the issue would be??
    vt berlina series 1
    Sep 2008
    mine does that , im told its the fan controller , behind the glovebox , i think , or its one of the vacuum hoses , pain in the a isnt it , mine only works on high
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VP_belina View Post
    You are losing vacuum. The easiest place to start looking is to make sure there is a thin vacuum hose connected at the rear of intake manifold. Make sure it is connected properly and in good condition. There should also be a one way valve on that hose, make sure it works also. If that is not the problem we will move on to the next likely cause.
    MY RIDE
    vs executive
    Nov 2009
    i have the same problem with a vt berlina i checked for vac leak 1 vac servo had a realy slow leak so i replaced it 57$ later and still the same problem when you accelerate or go up a hill air goes to the demist any more idears would be great thanks it is driving me crazy
  1. My VP Berlina
    By fu2 in forum VN - VP - VG - VQ
    Last Post: 05-01-2011, 03:14 PM
  2. My VY Berlina!
    By MYDZYR in forum VY - VZ - WK - WL - V2
    Last Post: 16-10-2010, 11:32 PM
  3. [VIC] Wanted: Vy berlina calais bar or vz exec/acc/berlina/calais
    By josh.meaden in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2009, 07:59 PM
  4. Vx Berlina Grill On My Vt Berlina
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 07:47 PM
  5. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
