Results 1 to 6 of 6
Thread: Caster settings
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Caster settings
    Does anyone know what the caster settings are for a VX series 1 VX with fe2 suspension are please . Cheers
    VX SS
    Jul 2005
    East of Melbourne
    I just recently had my VX SS aligned at a very good workshop on the latest equipment.
    The specs on the sheet they printed out are below.
    Caster Left: Min. 6.50 degrees - Max. 9.00 degrees.
    Caster Right: Min. 6.50 degrees - Max. 9.00 degrees.
    The print out actually uses a little '0' after the numerals, so I assume it is degrees,
    although I know some alignment specs are in 'minutes' as well. But the numerals above are whats on the printout.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Thanks guys , after i put new radius rod bushes some time ago i noticed that both the inside and outside of the tyres are wearing a bit faster than the centre .
    vt acclaim gen 3
    Jul 2009
    vic
    Caster figures should not affect tyre wear. I suggest you book it in 4 a wheel alignment, also what size tyres/rims are you running and what tyre pressure are you running as tyre wear on both outer edges can indicate under inflation.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by sly_gen3 View Post
    I have the standard 16 inch "s" factory mags , tyre presure is 38 psi
  1. caster bar bushes? how much to get replaced?
    By bardy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2010, 07:36 PM
  2. Help with Caster bar (yes I did a search)
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 02:35 PM
  3. caster busher damaged or faulty
    By vt5.0lt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2006, 07:11 PM
  4. caster rod bushes??
    By jerzey1234555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 02:23 PM
  5. VP Caster
    By sgo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2005, 09:48 PM
