Results 1 to 5 of 5
Thread: overheating
    VT Commodore V6 Berlina 3.8L
    Dec 2009
    Default overheating
    hi i have a vt commodore berlina as i came to the lights today pulling up temp gauge was at about halfway. Then it started to make a clacking sound then it just cut out and i couldnt turn the car back on!!!
    I opened the bonet and the car was extremely hot but no pressure in the hoses or nothing and it had no water in the raditor as i was putting small bits of water in the engine it was so hot it was just bubbling!!! The car started after putting a bit of water in it and with a little bit of accelration do u know what could be wrong???
    vt berlina series 1
    Sep 2008
    could be a lot of things , cracked tank in radiator, sticky thermostat, coolant leaking outa a split hose or the heater tap , wait till it cold then fill er up and see if you can see where its coming out of , betteryet tow it to your mechanic if your not too sure of what to look for , it could save you in the long run, it sounds like you may have been losing coolant for a while
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Do you know if the engine cooling fans were on at the time of overheating?
    MY RIDE
    Dec 2009
    im not sure if the fans where on!!! It only just starting cutting out when its really hot!!! Thanks will try new thermostat today it hasnt been changed in a while so its probably not letting water through cause its sticky!!! But thanks will let u know how i go
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    if its lacking water, then must be a leak somewhere, as mentioned when cold, put some water in it and see if u can find any leaks ,
    common ones again as mention above,
    heater tap (back of engine bay,drivers side,inline with battery) , its plastic so tends to crack
    water pump or water pump gasket (middle'ish pully in front of engine) ,so check for drips and front of engine
    spilt or loose hoses
    hole in radiator
    or dare i say, cracked head, head gasket
LinkBacks (?)
  1. 21-03-2012, 07:53 AM
  2. 10-01-2010, 09:18 PM
  1. gen 3 overheating???? help!!!!
    By Xfordman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2011, 10:18 AM
  2. How do i fix my car from overheating?
    By Inkar in forum General
    Last Post: 18-06-2010, 11:32 PM
  3. vn v8 overheating
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2008, 03:31 PM
  4. vp overheating :(
    By RIC_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2008, 12:30 AM
  5. overheating....
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2006, 06:56 PM
