Results 1 to 10 of 10
Thread: Temp Gauge
    Commodore vs Wagon
    Jul 2009
    Default Temp Gauge
    Hey guys with a vt series 2 does the temp gauge usually sit just below the halfway mark on the line thats below the middle?
    Once my car heats up it just sits on it never moves.
    Thanks
    VE Calais
    Sep 2008
    Cheltenham, Victoria
    mine does the same, it stays around about there whenever the sensor reads anything between what i think 80-110 degrees only when it starts going over that does it rise and when this happens.. it rises rapidly lol.. I ONLY just changed my radiator today - last wednesday when it was 40 degrees here in melbourne it somehow started a leak in my radiator was strange but after replacing it all is good!
    VX 5.7 A4
    May 2009
    Commodore vs Wagon
    Jul 2009
    so it is normal?
    lucky you got a new radiator becuause its only going to get hotter in melbourne lol
    well ihad a vs and to change to a vt its very diffrent as we no vs go up down up down but the vt just seems to sit there
    Thanks guys
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    Quote Originally Posted by cds View Post
    only when it starts going over that does it rise and when this happens.. it rises rapidly lol.. !
    sure does! and seems to only do that when radiator is nearly empty!
    VE Calais
    Sep 2008
    Quote Originally Posted by VTvoodoo View Post
    yeah a ;ong while back my heater tap bassically cracked, never knew there was a problem until suddenly bam from middle to hot and then the dash warning sounds going off. I dont know why holden didnt engineer this a little bit more logical = /
    VTvoodoo's Avatar
    VT Executive S2
    May 2006
    Gold Coast
    another Q , ive just done my water pump , and at same time i replace thermostat gasket, but reused thermosat (yeah , yeah prob should have replace thermosat at same time) , anyway i find now when on openroads, the temp only sits at just below quarter , not between half of quarter and half like normal , in traffic etc its fine
    is it possible thermostat is stuck open?
    or could there be other causes
    VX Executive
    Feb 2009
    what sounds wrong with my car. it sits a bit below half and read 98-101 degrees
    1 VX Acclaim
    1000's of possibilities
    VTvoodoo's Avatar
    VT Executive S2
    May 2006
    Gold Coast
    anyone? before i go and replace it,
    thanks
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I recon the thermostat is not closing properly, I would be replacing it. I doubt it will correct it's self, but only get worse!
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  3. temp gauge
    By SLO 057 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2008, 03:11 PM
  4. Temp Gauge went up ??
    By HoldenMan7 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2008, 01:14 AM
  5. where should the temp gauge for 5l vt sit?
    By wilko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2006, 08:39 PM
