Results 1 to 7 of 7
Thread: My VT won't run - barely idles - wont rev at all
    Jodamis's Avatar
    Jodamis is offline HSV911
    VT Aclaim
    Dec 2009
    Unhappy My VT won't run - barely idles - wont rev at all
    Hi everyone. Im new on here!!
    My problem is that one day my VT was running perfectly and the next morning it wasn't.
    When I start it, it coughs and splutters and sounds like a backfire at the front. It will not idle at all. When I dissconnect the Air flow meter it will idle very roughly.
    I called the RACQ and they said it is the fuel pump. This and the filter have been replaced with brand new ones. I still have the exact same problem. I have replaced the air flow meter too, but the same thing is happening. The computer error shows error codes 32 and 35 (air fow sensor (voltage out of range) and (IAC unable to control idle speed) These only just came up. they were not their originally. I have been working out of the Gregory's Commodore book (No.273)
    We are stuck with this and its ruined our christmas!!
    Can someone please help??
    VL V8 & supercharged VX
    Nov 2006
    western vic
    have u reset the computer take the battery neg off 4 a while then put it back on turn key on 4 40sec then off then another 40sec then started anything is worth a try as i can tell. and u gotta have the air flow meter connected even check around engine if any plugs have fallen off.
    WH Grange Gen3, VR V6 Commodore
    Mar 2005
    Happy Valley, SA
    Maybe a base idle reset will help, i needed to do it once.
    Take the engine fuse out for 5 mins, then after putting the fuse back in, start the car up and let it idle for 30 secs, then out in D for 30 secs, then P with aircon on for 30 secs, then in D with aircon on for 30 secs.
    Worked for me, worth a try.
    Jodamis's Avatar
    VT Aclaim
    Dec 2009
    Hi Alby1976 & blueV8Vl.
    Thanks so much for your help and info.
    I have done a reset on the computer. Now the car starts and runs. It is runnung very roughly but it is running. Its comming up with code 76 (auto problems), but that may be because it hasn't been driven. I took it for a drive and it has power, still runs roughly, but the auto still changes really smoothly. i haven't reset the computer yet though. Not sure why its running roughly. There are no strange knocks. It seems to putt a lot out of the exhaust. No smoke or anything odd comming out of the exhaust though.
    Warm regards
    VN Aero / Liberty RS Turbo / VL Turbo
    Nov 2009
    Dec 2009
    Could be fuel pressure either from a stuffed pump, faulty regulator or a blocked fuel filter. Change the fuel filter and see what happens if thats not it get the fuel pressure checked.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I had a problem recently where my car was running very badly, as in I stalled an auto many times. Turned out that my air-con clutch had burnt out which took the fuse out, which for some strange reason also powered the AFM, EGR valve, and purge canister.
    WHen the auto sparky hooked up his diagnostic device, it registered AFM code, transmission code, EGR code and something else.
    Check the fuse, then get a voltmetre out and hook it up to the 3-plug AFM connector, one should have 12V constant from battery, another ground, and another is 5V(?) front ECU.
    Ronald Reagan (1986)
  1. Help - My VS is barely running :(
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 08:53 PM
  2. VN idles rough won't Rev
    By aries75au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2008, 06:53 PM
  3. Tranny revs in 1st gear but barely moves
    By johnnyk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2007, 02:36 AM
  4. idles up and down
    By jayignorantz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 12:28 AM
  5. Vn V8 Idles High
    By NZVNSS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 06:28 AM
Tags for this Thread
