Hi i am looking for some advice with a issue i am having with my vt ss. I do not know what is going on at the moment it has 2 issues first it has a bad miss when you start to drive it its not all ways at the same time when i go to put my foot down it misses and trys to cut out then goes and it keeps blowing the injector fuse i have no ideas of what the hell is going on i am looking for any advice all so it is using fuel like there is no tomorrow i am at a complete loss any help or ideas would be great thanks
I had similar issues with mine not so long ago, the car would misfire under load, and struggle to start. After many headaches, and replacing the spark plugs, leads and distributor / coil the problem is now gone and turned out to be a drop in voltage coming from the coil (apparently it was stuffed).
It does sound like however there is a voltage spike in there which is blowing the injector fuse, this is likely to be related to the misfire. I'd recommend looking for any shorting out and running a multimeter over the wiring to ensure there is a constant, and steady voltage.
151 Countries, One Cúl-Báire!
Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
Cúl's AUII XR8 Ute!!!... Clicky Clicky!
that is when the fuse blows ill give it a go and see what happens my bcm came lose and would keep blowing the fuse as well i guess ill have to go through the wires
