Hi,
I have a VX 2000 Acclaim and everytime I start the car the warning lights all come on and stay on, the a/c doesn't work when the lights are one and the car makes a annoying melody when you turn the ignition key. I have read in the other forums that it may be my ABS module. I have read that if I disconnect the module then the lights go off that is definately the problem. Is this correct? When I did this the oil light and engine light went off and the low traction light came on. Is there another way of checking what else it may be, a fuse or something like that? Please help.
does sound like abs module and no disconnecting it wont tell you anything at least it didnt with mine.
Thanks for the reply. Did you manage to fix yours and if so how much did it cost ? If i bought one off ebay can we install it ourselves?? Any help would be great!!
