Results 1 to 17 of 17
Thread: Can anyone help out with an engine transplant?
    VT Berlina
    Oct 2009
    Default Can anyone help out with an engine transplant?
    Mods, please move this if it's not in the right forum.
    My car brokedown, and the engine is seized up, so a bought a VT ecotec for wrecking. It has a perfectly good engine and an aftermarket alarm system in it.
    What I need done?
    -Remove engine from my VT ecotec
    -Move engine from wrecking VT ecotec to my VT
    I have most, if not, all tools. I have occasional access to an engine crane, what I don't have is experience or complete knowledge.
    Will pay with either the $400 aftermarket alarm system or cash. PM me if you wanna help a fellow member out.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Hey mate,
    i wouldnt be too much use because i havent done a transplant before, but i'm keen as to help out or watch and learn a bit.
    Cheers.
    VT Berlina
    Oct 2009
    Quote Originally Posted by sweefu View Post
    Hey mate,
    Cheers.
    Still lacking knowledge and experience like me. hahah. I have the VT service manual CD but it's hard to understand and navigate through. I'm buying the Haynes VT repair manual book so hopefully that one is a little easier to follow.
    thedeadwalk's Avatar
    thedeadwalk is offline thedeadwalk
    VS executive S2
    Sep 2009
    newcastle
    VT Berlina
    Oct 2009
    Quote Originally Posted by thedeadwalk View Post
    buy a gregorys $50 from supercheap diy bible man
    Does that have engine removal as well? Also does it have sketches or pictures?
    Dec 2008
    the gregory's for my vl had pictures and a complete tear down and rebuild
    VT Berlina
    Oct 2009
    I might go pickup a gregorys one tomorrow then. Supercheap is having a 20% off everything sale again tomorrow
    Dec 2008
    VT Berlina
    Oct 2009
    I bought the Gregorys VT service/repair manual today, but I'm sort of dissapointed because I couldn't find steps for removing the engine and have been told that the Holden CD service manual has this.
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Hi Zaz im no mechanic but i have just swap my vt spac supercharged engine as she blew a bottom end with a standard ecotec until repaired , ill try and givve you a little info on how i did it. well first of all it is easier to take the engine and tranny all in one as it a prick to unbolt the tranyy of engine while still in car so you will need to jack it up so you can get under her to unbolt transmission bracket and the selector componants. You will need a somthing to stop the fluid from coming out of transmission when you finally pull it out and staining your driveway ,you can buy a plastic plug from supercheap auto for 15-20 but you will need to wrapped the end in tape as there not a perfect fit . with the engine we found it easier to pull the engine with the loom still all on just have to remove the plugs from the computer and the plastic plug the holds loom in firewall. You also wana unbolt your bolt from exhaust system from the headers to the pipes while you are under the car and leave headers on the engine to save stuffing the gaskets. Also remove your radiator to make it easier to remove motor and installing replacement motor and to avoid stuffing your fans and radiator. From memory you have to disconnect the + battery terminal as that wil come with the motor. Now the thing you have to take off are the radiator hoses ,fuel lines and mark them so you know which one feeds and returns ,vacuum lines and the hoses that go to your heater tap and thats about all from memory dont bother unbolting your starter motor as it will come with the motor and loom aswell. Also with the tranny lines unbolt the ones that connect up to your radiator as they will also come out with the motor as they are to hard to remove while in car . Also you will need to undo the high pressure line from the power steering pump
    as you dont wana stuff it a sthey are pretty expensive . last but not least the engine mount nuts under the car. Also leav ethe bolts that are bolted up to your tranny bracket till last as the motor might drop back and might make life bit hard thats all that i can remember its not hard we did my in my drive way which is on a hill so just take the time to look out for anything still connected whil pulling motor out. If you have any troubles email if you wont but im sure if you know a little you should be right ,it the only way to learn is do it .Also depending on where the after market alarm has been wiried into it might worth just cutting the wires and taking notes where they have been wired up to because if it has been wired up on the body loom thats a big job as you have to remove the whole dash to remove and replace with the loom from your wreck .
    good luck with it
    cheers bhopper
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    VN Commodore
    Mar 2009
    ey mate were are ya located? i havent done it on a VT before but i rekon i could do it.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    When you do it, Would be fantastic to put some pics up along the way to help people out in future. Just the main stuff would be tops.
    VN Commodore
    Mar 2009
  15. #15
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
  16. #16
    VT Berlina
    Oct 2009
    Quote Originally Posted by Drift_Clown_VN View Post
    I'm in Lyons, canberra. It would be great if you could help out. It would be good if there was a colour picture guide to removing an ecotec engine from a commodore so I will take pics along the way while doing it.
  17. #17
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by zaz96 View Post
    Please remember lol. i forget to take pics most the time when i do something lol
  1. VL engine transplant
    By Unit_01 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-06-2009, 09:23 PM
  2. engine transplant
    By beany in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2008, 10:56 AM
  3. Engine Transplant 5L or Gen 3
    By sus_calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-09-2007, 10:49 PM
  4. engine transplant
    By super_6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-05-2004, 11:02 AM
