Hi i have trouble with the ac in my vu ute the cold air only comes out of the demister vent is this a vacumn switch problem thanks chris
What happens when you move the switch to another setting, can you hear air escaping at all?
the air keeps coming out of the windscreen demist vent regardless of the position selected.No air escaping noise.
had similar problem pulled the a/c unit apart and behind the direction selector is a rubber gasket thing mine was pinched and squashed which meant it leaked and couldn't change the flow direction bought a new unit of ebay for 10 bux swapped it over no probs since
