Hi guys,
Of course on a day that it is 37 degrees outside, my aircon dies. Im not really sure what it is, maybe a fuse? I dont think its the water pump as the car is not over heating. When I go to turn the fan on (1,2,3,4) nothing is blowing out at all. Anyone else had the same issue? And anyone got any info on the fuses (or changed one yourself...)
Thanks (from a car hopeless mummy...)
Hi Leisanne, Welcome to the forum.
It Could be a fuse that has blown. But will most likely be the blower fan that has died. Remove the Dash panel below your steering wheel, just pull down on it, and use the guide to check the right fuse.
also check the relays they are located in the same place as the fuses i had like 3 - 4 of em die on me thought it would cost me a fortune as they are holden specific got em for like 6-7 bux each
