Results 1 to 14 of 14
Thread: Idle problem
    LYRIC Guest
    Default Idle problem
    Hi i am new to this site looking for some advise.
    im driving a VT s pak S/C V6 it runs really well considering i have no mods other than a high flow cat & a K&N pod, however my problem is
    when i take my foot off the gas between 70km - 100km the revs
    seem to fluctuate ( hovering ) between 1000rpm's & 1700rpm's.
    i have changed both idle & air flow sensors as well as the IAC valve.
    and the boy @ holden dealership are puzzled.
    can anyone help it would be appreciated.
    Thanx
    Lyric
    patrick Guest
    I had a similar problem with my previous car a VS. One of my mates suggested cleaning out the throttle body and it seemed to fix the problem.
    LYRIC Guest
    VT
    Apr 2005
    QLD
    could it be a problem with the supercharger bypass? just having a stab, but that is another thing i guess that could cause that problem....
    speters Guest
    i was just wondering if u knew where i could find a cold air intake system for a 3.8l v6 vt executive commodore?
    LYRIC Guest
    You could be right if the bypass has a slight leak it could couse a vac
    witch than could couse the problem.
    LYRIC Guest
    Speters
    Cheak out Forced Induction Technologies Ph: Tony on 0413 900 900
    Lyric.
    speters Guest
    VT
    Apr 2005
    QLD
    Quote Originally Posted by LYRIC
    or maybe in reverse effect, there could be little boost spikes causing the revs to fluctuate....
    LYRIC Guest
    But wouldn't that couse it to fluctuacte through the whole drive couse only
    does it between 70 & 100kmph ???
    VT
    Apr 2005
    QLD
    not necessarily...i believe it is electrically controlled so it could be a problem there.....
    LYRIC Guest
    Ok i'll try every thing you guys have mentioned and let you all know of the outcome.
    Appreciate the info i'll keep in touch i may be able to help yourselfs
    out sometime
    Lyric
    VT
    Apr 2005
    QLD
    LYRIC Guest
    Talking
    Ok guys i removed the throttle body and the IAC valve gave it a good clean with some carby & injecter cleaner, ( these things do get dirty )
    it has helped allot but still doing it a little bit but you can't notice it that much so i guess we are on the right track.
    Also FYI i got a spare key cut from MR.Mint cost was $150.00 for 2
    and they both work just fine, apposed to Holden charging $240.00 for 1
  1. VN V6 idle problem
    By Webster_140db in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2006, 11:04 PM
  2. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  3. Idle problem
    By DISTURBED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2005, 09:26 PM
  4. Vn Idle Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 06:25 PM
  5. Vn V6 Idle Problem
    By jackus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2003, 07:12 AM
