Results 1 to 13 of 13
Thread: Removing doors from VT
    '84 VH SLE
    Mar 2006
    Default Removing doors from VT
    Can anybody tell me how to go about removing the three pins that hold the front and back doors on? and how do these pins go back in afterwards??
    I have damage to drivers side front and rear door and am looking for a trouble free way to change them over for good straight doors.
    Any help is much appreciated, thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You have to knock the hinge pins out. You can use a punch or an old bolt a bit smaller in diameter than the pin and tap them out with a hammer. Disconnect the door loom first and have someone hold the door when you remove the pins because they are heavier than they seem.
    MY RIDE
    VT V8 Calais
    Mar 2007
    Just a tip with doing this, I found it far easier to get the hinge pin tool to do this. I tried a punch and other various things and all I did was make a mess.
    Door Hinge Pin Remover Extractor Tool Commodore - eBay Paint, Body Supplies, Tools, Car Parts, Accessories, Cars, Bikes, Boats. (end time 30-Jan-10 11:34:53 AEDST)
    Something like this makes it an easy job
    50LTRv8
    '84 VH SLE
    Mar 2006
    Thanks guys.....
    just a question, can you then use the same hinge pins when putting the new doors on?
    thanks
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think you should be able to re-use the pins if you don't damage them.
    MY RIDE
    VT V8 Calais
    Mar 2007
    The pins are reusable, they are just a narrow shaft with a threaded nut at one end, undo the nut, slide the shaft through the pin and then put the nut back on.
    The long bar has a grove which slides into the pin, and then you tap it with a hammer and it should come out. You could also put some WD 40 on and let that soak in before you start, might make it easier.
    50LTRv8
    '84 VH SLE
    Mar 2006
    Thanks a lot guys, will give this a try on the weekend.....free carton of piss to the man who offers a helping hand??
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by emmtee83 View Post
    im there ,lol wher you at
    executive vt 5.0lt
    Feb 2005
    west suburbs
    '84 VH SLE
    Mar 2006
    '84 VH SLE
    Mar 2006
    ok gungazza lives in NSW, no good to me!
    Looking for anyone in metro adelaide to help put two VT doors on, carton of piss in it for them. anyone?
    '84 VH SLE
    Mar 2006
    kym192's Avatar
    kym192 is offline kym j
    VH sl, VT berlina, VN berlina, VH SL\E
    Jun 2009
    south coast south aust
    hey where abouts in adelaide are ya pm me i just done my back door the other day might be able to help as i have the tool for the job
  1. removing all doors off vt
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2008, 10:54 PM
  2. Need Help! Removing car doors
    By zorac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2007, 06:28 PM
  3. removing vt doors
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2007, 02:42 PM
  4. removing god d**n vl doors
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-12-2005, 01:20 AM
  5. removing vs doors?
    By trent87 in forum Car Audio
    Last Post: 26-10-2005, 06:10 PM
