Results 1 to 6 of 6
Thread: VT VX sway bar difference best one
    vx
    Nov 2009
    Default VT VX sway bar difference best one
    i recently saw in that the sway bar and the sway bar links are diffrent between VT & VX
    VX sway bar link has a small ball joint on the bottom
    VT sway bar has rubber bushes on bottom
    both have the same rubber bushes on the top commenting to the shock absorber
    my question is is the VX sway bar better design than the VT ?
    also what is the best bush kit to buy is it the nalothane heavy duty kit ( i think they are polyurethane) or the rubber ones like the factory ones?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I've had both types of sway bars and link pins and I much prefer the VX type, it is much easier to remove the link pins and change the bushes. I've only used the rubbers bushes so I can't comment on the other types.
    MY RIDE
    vt s s1
    Mar 2009
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    The VX design is better, the VZ design with balls on both ends is better again. The ball design means the bushes don't get loaded up when the wheel turns, which leads to premature bush failure. VT's are renowned for spitting bushes out, whereas I'm yet to hear of any sway-link related problems on VZ's
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    vx
    Nov 2009
    danja's Avatar
    Jan 2006
    Quote Originally Posted by kalu View Post
    can i fit a double ball joint (VZ) sway bar link to a VT?
    You'd need VZ-style shock absorbers to take the sideways mounting link-pin, and a VX-VZ sway bar of course. Assuming all those bolt up (which I imagine they would) you should be fine. I've never tried it though, that's all hypothetical.
  1. Sway Bar
    By Joshren in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-09-2009, 01:45 PM
  2. VN sway bar> replace with VS sway bar?
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 08:11 PM
  3. VT Sway Bar
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2008, 06:20 PM
  4. sway bar...
    By nmj in forum General Discussion
    Last Post: 02-05-2006, 05:25 PM
  5. Best Sway Bar
    By death-from-above in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 05:53 PM
