Results 1 to 4 of 4
Thread: VX Acclaim Spongy Brake Pedal
    VX Acclaim Series 2 Wagon
    Jan 2010
    Default VX Acclaim Spongy Brake Pedal
    Just picked up a VX Acclaim Series 2 wagon, but the pedal seems really spongey. Don't know whether this is typical for this model with ABS or indicative of an issue. Can anyone advise whether the ABS affects the pedal feel?
    Cheers.
    1998 VT Acclaim S1
    Feb 2008
    Depends on what car you've been driving in the past...No ABS does not affect the feel of the pedal. The ABS will only ever activate under a set of conditions, otherwise its just the usual pneumatic brake. Check your brake oil levels and your brake pump is working. It might be worth taking it to a mechanic and have them check your brake pads if you needed new ones, and maybe to change the brake fluid and bleed the lines again if its needed.
    Jan 2010
    That was my assumption, just wanted to make sure it wasn't a 'peculiarity' of the VX Acclaim.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    If you have a spongy pedal, this generally indicates there is air in the system. Bleed each wheel cylinder (furtherest from master first eg, back L/H, back R/H, front L/H, front R/H) and see if this fixes the problem.
    Ensure there is plenty of correct fluid in the reservoir while doing this.
  1. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  2. spongy brake pedal adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-02-2008, 03:29 AM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. spongy brake pedal
    Last Post: 12-02-2006, 11:31 AM
  5. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
