Results 1 to 4 of 4
Thread: radiator differences 2 transmission lines or 4 transmission lines...
    VT Calais Supercharged V6
    Dec 2008
    Default radiator differences 2 transmission lines or 4 transmission lines...
    i just bought a new radiator for my supercharged vt got all the way home and pulled almost the whole old radiator to find out i have 4 points where the transmission lines connect to the radiator instead of the 2 that are on the new one they sold me, does anyone know what the difference is and why mine has 4?
    I think it has 4 because of the oil cooler but i would like to make sure... Or if anyone knows how to connect it up different so i just use to 2 points instead of the 4? Just saves me waiting till i get a chance 2moro to go all the way back to the shop to change it over
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    hey dark the answer to your question is that some radiators run dual oil coolers and some run single oil coolers,i have a supercharged vt and myn has four dual oil coolers if you wana play around with it you can get it to work but if you dont and wana run a dual can you take it back and swap it as i would for a super charged vt to help keep the oil cooler ,the single come out on earlier vt's .
    hope all goes well bhopper
    VT Calais 5lt
    Sep 2006
    on my radiator i have a pipe going from one side of the radiator to the other, i asume thats what your missing?
    VXII
    Jul 2009
    Default Connectors
    I have a WH Statesman V8 and just bought a Radiator off ebay for $190 delivered.
    The original Radiator had 2 connectors and the new radiator had 4 connectors.
    I just connected to the 2 connectors and its fine so the other side must be a separate cooler
    Dont know if this assists at all
  1. Transmission lines VX
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2011, 08:18 PM
  2. vn series 1 engine, new transmission lines?
    By cameron20020 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2009, 02:31 PM
  3. Transmission Lines
    By mick1979 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 06:41 PM
  4. changing transmission hose to and from radiator
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-10-2007, 10:12 AM
  5. Transmission fluid lines
    By pandaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2007, 07:08 PM
