Hi There,
Does anyone know if the indicator (WITH cruise control) stalk from the VY/VZ will fit a VT ?
The VT one is bulkt carriied over from VR/RS styling and has horrisd buttons.
I much prefer the later ones on the VY/VZ. Has anyone tried to fit a VY/VZ stalk into a VT ?
Regards & Cheers
Why VY/VZ?
The VX Series II and WHII will fit, and have the proper twisting cruise control...
Not 100% sure if they'll fit (they should...)
The Blue One
I remember there being a guide to re-wiring for the VX2 stalk, anyone know where it is?
Bought one this avo and would like to throw it in![]()
Here you go Dan VN.
Remember search is your friend.
VX 2 to VX 1 Cruise Stalk Conversion
I like my roo well done
i searched, but didnt find it till page 6, forgot to say id found it :P
Now to find blade connectors small enough to fit on the stalks one's .....
When i was looking for small blade connectors for my VR at the auto shop, the salesperson suggested i use "speaker terminals" which are just the right width. It worked a treat and had lasted without problems right up until i sold the car five years later.
I did the same on my VT, but shortly therefater i wired in some actual stalk wiring plugs off a VY/VZ wreck, from which i'd cut off the plugs. Although a lot of wreckers won't let you do it (unless they keep damaged harneses) some will such as Pick 'N' Payless at Blacktown (western Sydney) which is where i got mine.
Got mine all done this afternoon, instead of cutting plugs off my cars loom we made a little patch harness from the old plug to the new stalk
