Results 1 to 5 of 5
Thread: vt break caution light
    vn 5.0
    Apr 2008
    Default vt break caution light
    hi guys bought a vt the other month runs great and really happy with it
    but i noticed a couple of times when i break real hard the brake caution light comes on for a second or 2 then goes away
    the other day i done it then after driving for about ten mins put my foot on the break and my foot nearlly went to the floor felt like it had no fluid or something
    i still had breaks but they werent the same
    so i pulled over checked my fluid see if could see any leaks under the car and it was all good
    then every time i would break the caution light would come on kept on doing it for about a minute then hey presto brakes were back and have been ever since
    just wandering if anyone knows what the %$#@s goin on
    cheers
    1998 VT Acclaim S1
    Feb 2008
    I'm guessing you have 2 separate issues there, not necessarily related to each other...
    1. Your brake pump could be leaking around the seals. I'd take it to the mechanic and get them to check and if necessary replace the seals.
    2. Your park brake switch could be playing up. The brake caution light you're talking about there has nothing to do with your brakes. Its a warning light when you have your park brakes on in case you were tempted to try and drive off with it on. In saying that, might as well get the mechanic to check your park brakes too while they're doing your brakes.
    vn 5.0
    Apr 2008
    yeah in the handbook it says it is directly for the brakes as a whole
    i changed my brake pads today and bled them just in case there was some air in them
    now the light doesnt come on at all even when i brake reall hard
    so hopefully just needed some love a
    if it happens again i got a feeling might be the booster seals
    VXII
    Nov 2009
    Low brake fluid level caused your warning light. When you brake hard, the fluid in the resevoir rushes to the front chamber and the float in the rear chamber drops onto the contacts, and lights your dash symbol.
    The handbrake light, brake fluid level and brake pressure fail warning light is the same light on the dash of most cars.
    A brake booster seal/diaphragm leak won't cause this light to illuminate, just a hard brake pedal.
    vn 5.0
    Apr 2008
    yeah cheers mate
    maybe that was the problem the brake fluid level was spot on but the brake pads were real low maybe when i braked hard it sucked down most of the fluid
  1. Wiring for the wing break light
    By RedBull77 in forum Electrical Wiring / Questions
    Last Post: 24-07-2009, 03:40 PM
  2. Break light issue
    By LUMINA ANIMUL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2007, 04:28 PM
  3. how do i fix break light on back of ss ute roof?
    By djvsa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2006, 11:31 PM
  4. Break light
    By Ristof in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-04-2006, 01:17 PM
  5. VU sports bar break light
    By Bowdz in forum Electrical Wiring / Questions
    Last Post: 11-11-2005, 02:34 PM
