Results 1 to 4 of 4
Thread: VU Ute seat issue
    01 VU S Ute
    Apr 2006
    Country Vic
    Default VU Ute seat issue
    I am needing to fix the drivers seat side plastic panel that has the seat adjuster on it.
    The part that gets screwed into the bottom of the seat has cracked and wont screw up.
    I was going to glue a couple of washers to either side of the cracked part so that it wont slide slide out when screwed in.
    Just wondering as cars can get very hot what is the best glue to use for this, The dealer tried to fix it twice but it is still doing it and I am guessing it is the adhesive they are using as it was fine the last time until there was a hot day.
    Thanks
    Dont spam that rubbish in your signature
    01 VU S Ute
    Apr 2006
    Country Vic
    Anyone know of anything
    I am going to try super glue, would this be ok
    vn 5 litre
    Nov 2007
    happened to me mate i just drilled another little hole in the plastic and than zip tied it to under the seat in a few spots works a treat hope that helps
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    yep,i had same problem and same fix as gav...
  1. VS ute bench 2 seat to bench seat conversion.
    By dazzavs00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2011, 07:20 PM
  2. bcm issue
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2009, 08:23 PM
  3. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  4. VS Oil Issue
    By Mecgun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 09:56 PM
  5. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
