Results 1 to 4 of 4
Thread: radiator mystery
    vt calais
    Jul 2009
    Question radiator mystery
    hi thought my sons vt had a radiator leak checked it out and found water was coming from overflow bottle took it out cause i thought that might have a leak no leak so left it out as the son wasnt driving his car for a couple of days since last saturday 9-1-10 and then to my surprise noticed water coming out of the overflow hose that goes from radiator to overflow bottle this was with the engine cold and not started for two days i know its been 43 degrees today in melbourne but how can the water bypass the radiator cap anyone else had this problem with their vt
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Maybe the radiator cap is stuffed. Have a look at the seal
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Water expands when heated up (even by one degC). Water is not compressible! There is 12 liters of water in the sealed system, so when it heats up and expands (even on a hot day) it has to escape somewhere, so its out of the radiator cap into the overflow pipe, as it's designed to do.
    When the water pressure reaches the 'blow off' pre determined pressure of the cap spring, it releases water, otherwise it will split the core or pop a hose.
    vt berlina series 1
    Sep 2008
    like the guy above said , check the radiaor cap if the rubber is all cracked get another one
  1. my little mystery...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 05:20 PM
  2. Mystery Noise
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2007, 01:47 PM
  3. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
  4. Mystery Plug
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2007, 11:38 AM
  5. Mystery Cable
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 10:30 PM
