Results 1 to 11 of 11
Thread: Air con hissing
    VXII S
    Jan 2010
    Default Air con hissing
    Air con is hissing but no cold air. from the inside of the car . Where would you all look first.?
    mwb235 Guest
    The hissing sound usually means your aircon system has run out of refigerant (gas). This means you have a leak somewhere. Aircon gas never "runs out" rather it leaks out somewhere. Take it to an aircon specialist and get them to pressure test it (preferably a nitrogen test).
    If you're lucky it's only a minor fault like a dodgy schrader valve or o-rings etc. If so you'll just need to replace these then have it re-gassed.
    If you're unlucky it'll be the aircon compressor (lots of $ to replace - i just did mine recently). If this is the case check this thread: air con comressor
    But i suggest you do a search on these forums using words like "aircon hissing" etc, it should yield several results that discuss this issue.
    VT spac super6
    Nov 2008
    Riverton sa
    How does hissing mean its out of refridgerant?
    Does the hissing continue for a few seconds once the car is turned of? its likely to be a vacuum leak in the back of the heater controls..
    to test the a/c issue, start the car and turn the a/c on, open the bonnet and have a look at the compressor, (bottom pully on passenger side) if its turning on, the whole pulley will be spinning if not the centre will not be moving its a magnetic clutch
    VXII S
    Jan 2010
    the hissing continues the whole time the air con is on. when i turn it off i will have to check that. i have removed all the dash and can hear the hissing around the back of the glovebox but cannot detect the leak from any source.
    VT SS 5.7
    Aug 2006
    Western Suburbs/Melbourne
    The heater is behind the glove box
    Maybe its got a hole in it,another guy on here had the same thing
    Ants wanna b V8 supercar VT 6
    This is the page from his thread (in the middle)
    Its a dash out job,if thats the problem
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by GE4CE View Post
    heater core is on the driver side more so than passengers + he would be losing coolant, seeing the drips left from the drain hole and smelling it...
    if you look up under the dash on the passsenger side you can pull the plastics out, on the LHS on the a/c-heater assembly there is a little box (round edges) with 2 vac lines leading to it thats the accumulator for the system be a good place to start for a leak on that side..
    do all directions still work etc?
    VT SS 5.7
    Aug 2006
    Quote Originally Posted by HARVZ-6 View Post
    Hes got some good photos of the evaporator core,maybe thats the problem
    VXII S
    Jan 2010
    air con bloke reckons 99% that it is the compressor. he reckons they only last about 5 years max. but will check out today.
    VH Commodore
    Jan 2010
    Quote Originally Posted by njf690 View Post
    BULLSHIT!
    I do AC and have never heard that load of crap before. I'm not saying it isn't the compressor but saying they only last 5 years is rediculous.
    mwb235 Guest
    I had my compressor replaced in December 09 and it was the original factory unit. My car is Aug 98 so that's just over 11 years - not bad (237,000km travelled).
    I decided to go genuine as (1) i think 11 years is very reasonable and (2) i'm sure i will have updated to a newer car by then anyway (i've already had my VT for 3 1/2 years).
    VXII S
    Jan 2010
    was the compressor and the dryer has not been replaced and it was gone to. not bad 8 yrs old with 87000km on the clock. but not good when trying to sell the car to have this expense. $1100 to do the lot with dryer, compresoor, seals, regas and anything else.
  1. Hissing from air con
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2009, 04:53 PM
  2. Gen 3 V8 hissing noise
    By bails in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 03:39 PM
  3. Air Con Hot and Hissing me off
    By Bradles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 12:50 PM
  4. hissing VL
    By livenletspool in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2004, 11:10 PM
  5. Hissing Noises
    By mustapha in forum Electrical Wiring / Questions
    Last Post: 20-04-2004, 07:16 PM
