Results 1 to 4 of 4
Thread: Vt slight misfire at low revs / slugish when hot
    VT S2
    Dec 2009
    Unhappy Vt slight misfire at low revs / slugish when hot
    Hi,
    My vt series II has a slight misfire, which is noticeable at idle, also the car has a shudder and loss of power when accelerating, this gets worse when the car gets hot ie 10/15 mins. These problems are not so noticeable when the car is cold.
    Ive had replaced recently;
    Plugs, Leads, Fuel Filter, Engine Mounts
    Also ive cleaned the throttle Body. an attempted to clean the plenum chamber haha. But this hasn't made to much difference.
    any assistance would be appreciated
    1998 VT Acclaim S1
    Feb 2008
    VT S2
    Dec 2009
    1998 VT Acclaim S1
    Feb 2008
    Start from your spark plugs, follow the leads back and you'll finish to a block thats has 3 circular poles marked 1 to 6 for a V6, or 4 poles marked 1 to 8 for a V8. That would be your coil pack. As far as testing goes, it won't be easy doing at home unless you have the right gear. Best to get it checked at a mechanics or just drop in a new coil pack.
  1. Car slugish
    By Matt83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2009, 10:46 AM
  2. VT slugish
    By arty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2008, 09:28 PM
  3. VS Wagon running slugish
    By dexta182 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2006, 12:00 PM
  4. VS auto Slugish kickdown
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2005, 06:24 PM
  5. Slight Revs
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2005, 02:52 PM
