Results 1 to 18 of 18
Thread: Overheated VT - Pink fluid in radiator
    VT Executive
    Nov 2009
    Default Overheated VT - Pink fluid in radiator
    Hi,
    My VT overheated today.
    When I opened up the radiator it was full of pink fluid, as was the coolant refill tube.
    Is this likely to be coolant or something else?
    The car was fine before christmas, left it in the garage while I was away for a couple of weeks, now this.
    It also stalls and over revs at times.
    VX Acclaim sc L67
    Mar 2009
    nth qld
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Definitely transmission fluid in the cooling system, the transmission pipes go though the radiator for cooling and I would say that the leak is in the radiator, so you will probably need a new radiator. Check the transmission fluid to see if any water got into transmission, you might be lucky and find nothing but I would not drive it or you might cause major damage to the transmission.
    MY RIDE
    VT Executive
    Nov 2009
    Sep 2004
    some jap cars take pink pink coolant so check to see if previous owners didnt put the wrong coolent in!
    BXHD Guest
    my VZ has pink coolant in it and its wat holden put in.. so get it checked properly before u listen to everyone on here
    VT Executive
    Nov 2009
    Thanks for that BXHD!
    Assuming it is the radiator and I need a new one, I can see that Series 1 and Series 2 VT need different radiators. How can I tell which series I have? The date of manufacture is 05/2000.
    Quote Originally Posted by BXHD View Post
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    2000 will be a series 2.
    There is a pink coolant, not usually used in the V6's, but it's possible someone has put it in. Easy enough to check though, transmission fluid will be oily (it's an oil after all), whereas the transmission fluid will have the consistency of water. Get some on your fingers, and mystery solved.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    BXHD Guest
    my car overheated on monday, and i took it in to get looked at, my radiator is being sent off to get cleaned out properly.. and my fans malfunctioned..
    i didnt really know wat was wrong with my car until i put water in the radiator, and took it for a 20 min driver yesterday watching the temp the whole time, (was cold, and the temp didnt go over 1/4)
    so i figured a blocked radiator..
    best advice i could give u would be, if ur not sure wats wrong, get it looked at because its not worth a new engine if u screw up
    im pretty sure u would have a series 2 vt
    VT Executive
    Nov 2009
    Yeh it does seem to be coolant.
    When I refill the radiator from the hose and seal it as best I can, after a while water and pink stuff comes out from a hose connection to the coolant refill tube.
    My guess is that the clamp dried out while I didn't drive it for a couple of weeks.
    You're right, have to be very careful not to kill the engine.
    Re trans fluid or coolant, it does feel and look a bit oily. Actually it's like coagulated paint - kind of slippery in water but sticky.
    VT Executive
    Nov 2009
    Things are looking worse.
    The transmission dipstick has the same pink fluid on it, but it's very low.
    The bad connection is between the radiator cap and the coolant tube but there must be something else wrong.
    VT Executive
    Nov 2009
    Took it to the mechanic, I do have water in the transmission..
    Anyone know where to get cheap transmissions in Sydney?
    Mechanic is saying he can flush it but it will die in a few months...
    BXHD Guest
    VT SS Series 1
    Nov 2009
    Damn! Same thing happened to my BA XR6. Apparently a common thing on the Falcon. Happened just before chrissy and the transmission is screwed too.
    I feel for you, as soon as i saw your post stating "pink fluid"!
  15. #15
    SSZ 5.7LTR & 01 VX V6 Supercharged
    Aug 2009
    Toowoomba
    Quote Originally Posted by just_vt_problems View Post
    Get a second opinion 1st , its cheaper than a new box.
    Exact same thing happened to mine and my auto was cleaned out real nice, no problems at all just had to get a new radiator.
    Good luck.
  16. #16
    danja's Avatar
    Jan 2006
    Get the trans fluid totally flushed, hopefully you caught it early enough that there isn't serious damage.
    If it does die you can pick up 4L60E's fairly cheap on eBay a lot of the time, or a wrecker. Used to see them all the time around the $300 mark (more if properly reco'd though)
  17. #17
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    Quote Originally Posted by D_BLOCK View Post
    Good luck.
    Same here, had this issue with my VX. Cleaned it out good, gave the trans a good service and never had any issues. Good luck.
  18. #18
    VT Executive
    Nov 2009
    Thanks guys, I will get the fluid changed again.
    Anyone have negative stories related to changing the fluid after the trans got water in it?
    I'm being told that once it gets water in it, it's !@#@-ed.
  1. Trans fluid leak - radiator
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2009, 07:26 AM
  2. How do I change the radiator fluid [VR]
    By CrimsonThunder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2009, 08:36 PM
  3. Changing Radiator fluid/Clean - Help
    By brayden_87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2008, 03:00 PM
  4. Leaking Pink Fluid
    By Vz_ChiC in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2007, 08:30 AM
  5. changing radiator fluid
    By maccona35 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-06-2006, 05:04 AM
