Results 1 to 9 of 9
Thread: vt commodore blinker problem
    vt acclaim
    Jan 2010
    Default vt commodore blinker problem
    ive got a 1998 vt commodore acclaim and every time you turn the blinker off, you can still hear the clicking coming from dash area. what would be the problem or how do i fix this its driving me nuts. please help me
    VT S V6 LPG
    Jun 2006
    check the relay in your fuse area under ther steering wheel, most likely needs replacing holden charge about $25 for the part.
    edals's Avatar
    edals is online now Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Does the cliker speed up when its off? Mine does the same. Its the stalk its self asi replaced it with a cruise control stalk and done it ever since, very minor connection and casuing it to click. only happens if i gentle turn the indicator off though.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Same problem, I fitted a new stalk assembly and problem solved. Common fault in the Commys, so I was told. New one with cruise was just under $40.
    I then pulled the old indicator stalk to pieces, and found that it was NOT worn out, but the grease had gone a bit hard across the contacts and had picked up a trace of copper in it from the contacts. This was enough to allow a few milli volts to track across and activate a section of indicator relay (without the globes flashing) when the stalk was in the neutral position.
    Next time I will wash out the old switch grease and re-assemble. Prick of a job, but it can be done.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by pablo View Post
    Thanks for the tip, Think ill do that to mine and see what happens
    VT - Commodore
    Nov 2009
    Yep same thing happened to me and was driving me insane. kept on ticking as soon as you touched the blinkers etc. replaced the stalk and fixed it.
    Warface is offline No time for anything!
    VT Calais II Supercharged V6
    Jan 2010
    South Morang
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Im not going to state the obvious here. Not worth the 1000'th thread on it imo.
    Click here for the fix.
  1. blinker problem VS
    By festar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2009, 06:45 PM
  2. VT blinker ticking problem
    By vlv8vic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2008, 09:48 PM
  3. Blinker Problem
    By hughsy76 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2008, 03:17 PM
  4. Blinker Problem
    By djhoghunter in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2008, 09:51 PM
