Results 1 to 5 of 5
Thread: VS V8 Engine into a VT
    Dec 2005
    Talking VS V8 Engine into a VT
    Gday all.. I,ve got a v8 engine that came out of a series 2 VS and want to put it into a VT .. is there any problems with doing this, would it bolt up and work.
    Cheers ALL
    VX SS II 6.3L/M6
    May 2005
    physically it should fit, but you might have issues getting it registered. In order to use an older engine than the one released from factory, it has to meet certian epa rules. You'd have to upgrade the engine to include all the extra parts found on the VT V8.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by feistl View Post
    in which case your better off just buying a vt 5lt.
    i'm also pretty sure that the motor has to be newer than the build date of your specific car. but i could be wrong with that one
    Chev badges are an instant fail
    VXII
    Nov 2009
    Extract from RTA website:
    Emission standards for replacement engines:
    1972 and later model vehicles with substitute engines must meet the intent of the later of the Australian Design Rules applicable to either:
    a) The original vehicle; or
    b) The substitute engine.
    So, unless your replacement engine has the same or better emission standards than the car's original engine, don't bother.
    more at:
    http://www.rta.nsw.gov.au/registrati...s_nov_2007.pdf
    Dec 2005
    Many thanks everyone.. i,ll scap that idea. cheers all
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  3. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  4. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
