Results 1 to 3 of 3
Thread: I want to change my battery leads in VT, what do I need to consider before I start ?
    98 executive
    Jan 2010
    Red face I want to change my battery leads in VT, what do I need to consider before I start ?
    My Battery leads are loose in my VT and I have the ends to change them, is there anything I need to consider before I start?
    VX SS II 6.3L/M6
    May 2005
    For a short term measure you can do the following.
    Get a ring pull from a softdrink can, bend it slightly in the middle and slip it in beside the battery terminal. It spaces out the contacts slightly so the current leads will clamp down again.
    Did that to a mates car who was too cheap to fix it properly... 2 years later and its going strong :P
    VX Executive S2
    May 2006
    Frankston South Vic
    Draw a diagram of where leads go before pulling it apart
    make sure you have the radio pin if stock head unit, Turn off siren if battery back up alarm, Remove negative lead first, then positive. When refitting fit positive lead first, then negative. Double check where leads goto before reconnecting. Sorry if i have over simplified but i don't know your level of experience
  1. Car need jump start with new battery!!!!!
    By AttaBoy in forum General
    Last Post: 03-08-2008, 01:46 AM
  2. How do you change Ignition Leads
    By kaishiz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-04-2008, 07:07 AM
  3. ute missing when idle plugs and leads change
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 06:26 PM
  4. Vt Won't Start After Taking Battery Out
    By revvy67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2006, 11:27 PM
  5. Replies: 1
    Last Post: 17-01-2005, 05:39 PM
