i need to replace the flasher relay for the indicators.
i bought one, but the man in the shop said it had to be fitted really carefully as to not blow a fuse.
i thought you just pulled it out and slid the other one in?
thanks
its a vx commodore
"Three words....
"Plug and Play"
I like my roo well done
if he gave you the right one then yes it is a simple swap over, if it is just a universal flasher sometimes the pins arent the same. if your fuse blows then you will prob need a holden one or you can make up some short leads with terminals to match the right pins together
thanks for all your help guys.the other problem is i don't know which one it is to replace it.
