hey
i had the same problem with my 1992 vp calais. all i did was clean and check all the bulbs and connections 2 make sure all the bulbs are working. then disconnect the battery for a few mins which will reset the computer and clear the fault out of memory. I've never had a problem with it since. if all ur bulbs are working u might just get away with disconnecting the battery but make sure u have ur radio code if u got the original stereo in it!!!
Give it a go
LinkBack URL
About LinkBacks
