Hello Guys,
My air cond died ägain" last time it run low on gas as far as i can remember the fans still operated just the compressor didnt cut in? Can anyone confirm this?
it was regassed and had new seals installed less than 12 mths ago, I am not sure if this is another gas problem or a elec problem this time, Any easy way of checking? with the button in and the light on neither the compressor or the fans cut in.
Thanks...
Kevin
my vt's completely out of gas and neither fans or compressor turn on,
last time i got it filled- as soon as he hooked up the refill bottle and put enough pressure in the system the fans came on with compressor.
Your car is fitted with a air-con pressure transducer. What this does is detect high pressures and low pressures.
And cut the system out or off. For what ever reason eg: Low gas or over charged system.
They do this to protect the system from running and further damage.
Sometimes the air-con transducers go faulty. Also check the relay for the compressor
by pressing the switch and checking the supply to the relay.
The power train control module supplies a earth signal to the relay see if its giving out.
And if it is the relay should click in and supply power to the compressor. Also check the fuses
this is for a v6
