Results 1 to 6 of 6
Thread: VT Wheel Size Help
    VT Berlina Sedan
    Dec 2009
    Default VT Wheel Size Help
    Hey guys,
    I have a 1997 VT Berlina which has 15" Alloys on it at the moment.
    Im looking for new rims but I just got new tyres so i need to keep it 15" for now.
    Now i understand the size on mine is 205/65/15
    so would i have to get that exactly or would 205/60/15 or 205/70/15 fit?
    Cheers.
    PS that is the size on the wheel (205/65/15)
    vt acclaim gen 3
    Jul 2009
    vic
    yes 60 and 70 series tyres will both fit. But why would you change away from the 205/ 65 /15?
    VX SS S2 5.7
    May 2009
    id wait till your due for tyres then get bigger wheels, 15" mags look heaps small on a vt
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by turboads View Post
    You have a series 2 VX i see. VT's have camber problems, the bigger you go with wheels, the worse it gets.
    The 60 and 70 (middle number) is the sidewall thickness is it not?, so any variance in that isn't the problem, just variance in the first and last numbers is where the problem will arise.
    VT V6 Executive S1
    Nov 2007
    NSW, Central Coast
    Quote Originally Posted by jazza15 View Post
    As far as sizes on the tyre is concerned the 60 and 70 (middle number) is the "aspect ratio" which is the relationship between width and height. To get the same height, that is, overall diameter, which equals the same revolutions per kilometer, and also speedo reading, the equivalent to 205/65x15 would require 195/70x15 or 215/60x15.
    As for the size on the wheel itself, the usual designation should be 6.00J(or K)15,
    6.50J(or K)15, 7.00J (or K)15 etc.. The 6.00 is obviously the rim width, the 15 is equally obviously the rim diameter, and the J or K (on steel wheels) defines the gauge or thickness of the metal of the rim. The higher the letter in the alphabet means the thicker (stronger) rim.
    On most Alloy Rims that I have seen, the letter is dropped leaving the designation as 6.00X15, 6.50X15 etc..
    However, I have never seen any wheel (Steel or Alloy), where the specific tyre size, as in 206/65X15, has been used to designate the wheel size. I am open to correction on this matter if someone can quote specific instances, photographic proof would obviously put me right on the spot.
    Hope this helps somebody along the way.
    VY Calais
    Jan 2010
    get new wheels, 15 is too small for such a behemoth
    VY Calais, LS1, 19's, Lowered, VY2 Front bar.
  1. Wheel size on vy ute?? how big can i go????
    By hbdvysute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-10-2009, 08:36 PM
  2. Wheel size law
    By calais24/7 in forum General Discussion
    Last Post: 28-09-2009, 03:25 PM
  3. Wheel Size?
    By davo3569 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2009, 06:08 PM
  4. wheel size
    By boonga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2008, 06:27 PM
  5. Wheel Size Please
    By holden69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 11:16 PM
