Results 1 to 6 of 6
Thread: Super6 Misfiring when Hot on WOT
    azza77 is offline Kiss my coight
    VX S2 Super6
    Aug 2009
    Novacastrian
    Default Super6 Misfiring when Hot on WOT
    Ok lads, as the title says, im having trouble with my super6 misfiring when it gets hot but only on 1/2 to WOT? It platters and sh1ts its self over 3000rpm when its at a decent running temperature (30mins heavy foot driving). When i first start up its fine and when its warm enough to go i can get stuck right into it without a drama but once she warms up a bit thats it. Ive replaced the leads, spark plugs and cleaned the injectors without any success. I do have other thoughts as to what it might be but i just want to get everyone elses opinion first. Thanks in advance.
    Azza
    VS l67 statesman
    Dec 2008
    Usually if its heat related its electricals try your coils and control module plate
    VX S2 Super6
    Aug 2009
    Novacastrian
    Quote Originally Posted by vsl67 View Post
    Yeah, ok, thinking about taking it to holden on wednesday and running some diagnostics.
    Azza
    VX S2 Super6
    Aug 2009
    Novacastrian
    VT SUPERCHARGED
    Oct 2006
    Your coolant temp sensor has a wire runs off he throttle position sensor maybe see if you have any fault codes.
    Attached Files Attached Files
    VT spac super6
    Nov 2008
    Riverton sa
    Sounds spark related...
    only takes a slightly dull spark on one pot to send them into a spitting fit when they come on boost
    get you coils checked out
  1. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  2. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  3. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  4. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  5. misfiring
    Last Post: 18-06-2006, 11:36 AM
