Results 1 to 10 of 10
Thread: VX II Power Window Problem
    SHANBANGER's Avatar
    SHANBANGER is offline Der Meister
    1997 VS S2
    Aug 2008
    Kyabram, Goulburn Valley, Victoria
    Default VX II Power Window Problem
    Hey guys i had a quick search and couldnt find what i was after. In my mums VX II Berlina, the drivers side rear power window is playing up, it goes down but wont go up so the window is stuck at a quarter open. What could be causing the problem and how would it be fixed?
    Cheers,
    Shannon
    MY VS - http://forums.justcommodores.com.au/...executive.html
    You have a pussy, i have a dick, so whats the problem? Lets do it quick!!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Does it happen with the main switch and the rear door switch?
    MY RIDE
    SHANBANGER's Avatar
    1997 VS S2
    Aug 2008
    Quote Originally Posted by accentstencil View Post
    yeah mate it doesnt go up with the main switch or the rear door switch
    VX 'S' S1
    Apr 2005
    South East,Victoria
    could be in the wiring loom that goes from the pillar the the door. My right hand rear plays up but works arter i give the loom a bit of a jiggle .
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Dayvo View Post
    That's my guess also.
    MY RIDE
    SHANBANGER's Avatar
    1997 VS S2
    Aug 2008
    I tryed giving it a good jiggle but that didnt get it moving, any other ideas??
    2001 VXII SS Commodore
    Nov 2009
    i had the same problem and turned out to be my loom. had me a bit screwed as I took apart the switches and cleaned the contacts etc (which probably will help in the longrun anyway).
    Putting in my new looms in a couple of weeks.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Shan_VS View Post
    There's a good chance you have a broken wire in the rubber boot.
    MY RIDE
    VX SS S2 5.7
    May 2009
    try squirting the connectors with a bit of electrical cleaner helped with my rears
    SHANBANGER's Avatar
    1997 VS S2
    Aug 2008
    Thanks for all you suggestions guys. Took it to my mechanic and it turned out to be a broken wire in the rubber boot. Just as you guys said. Thanks for all of your advice
  1. power window problem
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 12:57 AM
  2. VX Power Window Problem
    By the_bazz17 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2009, 06:43 AM
  3. power window problem
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2009, 07:43 AM
  4. Power window problem...
    By Cyph3r in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 03:11 PM
  5. VY Power Window problem?? - HELP!!
    By Fester1548 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-12-2006, 09:17 AM
