Results 1 to 10 of 10
Thread: VT Error Code woes - 23,32,35,73 HELP
    98 VT 50th Anniversary
    Jan 2010
    Default VT Error Code woes - 23,32,35,73 HELP
    G'day....I have been trying to search on this website as to what I need to do to fix error codes 23,32,35 & 73.....I have been unsuccessful, although the answer is probably in here somewhere. Please help as I cannot use my car in the present state. cheers
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    VT SUPERCHARGED
    Oct 2006
    Quote Originally Posted by Louieg View Post
    From the info i have.
    23/ air temp sensor /voltage high
    32/ air flow sensor /voltage out of range
    35/ idle speed error/ iac unable to control idle speed
    73/ pressure control solenoid gearbox
    Jan 2010
    thanks Edals / Becs, I do have a list of the codes but I do not have any idea how I can fix? Sorry I should have been a little clearer
    Jan 2010
    Ok, I reset codes....The problem code now is 35.......Is there any particular part that I need to change to fix the problem I have?
    Problem - Rough Idle on start up, cannot put accelerator down quickly cause it backfires (I think through the air filter). Car will not drive because of the previously stated problem. Looks like car is taking in too much air and not enough fuel.....Could it be the fuel pump? I changed the fuel filter but didn't make a difference. Cahnge the sparks/leads/coils...didn;t make a difference...
    help is needed please, pretty please with cherries on top!
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Your IAC Is faulty or clogged up with carbon by the sounds of it, COde 35 is your IAC (Idle Air Control), and would explain the unstable idle you have. You can try cleaning it, its just on the top of the throttle body, Use this as a guide to help remove the throttle body and clean both, its from a VR, but process is similar.
    CleaningThrottle Body VR V6
    If it still has issue, i would replace the IAC, they are about $99.
    Jan 2010
    thanks edals. Anything is worth a try......I juast got a message from Dr Bob and he reckons the fuel pump might have crapped itself, which would also explain a lot of things....I might give the IAC a clean up first, and of course if this fails get the fuel pump replaced......thanks again. cheers
    VT SUPERCHARGED
    Oct 2006
    Jan 2010
    Thanks for all of the suggestions guys. My problem has now been fixed. The Fuel pump was faulty.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Well thats good to know for future :-), thanks for sharing your fix :-)
  1. error code 47
    By mynameisearl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2011, 05:05 PM
  2. 95 VS, Error Code 47
    By _tilt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2009, 09:41 AM
  3. Error Code 44 and 76 - how do i fix it
    By the_cookster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2008, 07:31 AM
  4. Error Code 44 / 64 92
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 08:17 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
