Results 1 to 2 of 2
Thread: ABS cable
    VT Executive
    Jan 2010
    Default ABS cable
    I was putting in new brake pads, caliper slipped out of my hand and fell onto abs hose/cable (sensor?). anyway, it broke it off from the connection to the disc and it cannot be reconnected, what should i do? do i need a new abs module, or a new cable?
    VE SSV
    Apr 2006
    hey mate, the ABS Module is located in the engine bay, so could could not have damaged that ...I'm pretty sure you are talking about the ABS cable/hose/sensor. If its broken you wont be able to fix it with a hammer and a nail if you know what i mean. Just go to the wreckers and buy a second hand one and put it in. Wont cost you anything, its better than doing a temporary fix and your brake fails...then your introuble. Good luck
  1. Cable
    By freddie142 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2009, 12:52 AM
  2. 95 lexcen bonnet cable will a VR cable fit?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 04:19 PM
  3. kickdown cable
    By mundine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 07:00 PM
  4. rem cable
    By ben k in forum Car Audio
    Last Post: 20-04-2006, 05:45 PM
  5. Throttle Cable
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 10:02 PM
