Results 1 to 3 of 3
Thread: how to read error codes
    VT S2
    Dec 2009
    Question how to read error codes
    hi,
    alright so I've tried several times to check my vt for errors, ive read on here that its possible; i use a paper clip and i bridge pins 5 n 6 under the dash then turn car to on and i'm suppose to count the light flashes.
    but this dosnt work, all that happens when i do this is i blow my ecu fuse and/or get serv. error so the car pretty much wont function at all. btw replacing the 10a fuse under the bonnet stops the serv. error and the car will funtion again (if anyone else is having the problem)..
    but can any body help me?, would rather not have holden charge to do this, if it is possible to do at home
    VT SUPERCHARGED
    Oct 2006
    Not sure why you are blowing fuse unless you have the wrong plugs
    Attached Thumbnails Attached Thumbnails how to read error codes-diagnosis-connector.jpg
    VT S2
    Dec 2009
    thanks mate! worked that time. maybe i had the wrong pins..
    i seem to be getting the following codes, so pretty sure i'm reading it right
    12,31,43,92,12
    then repeats
LinkBacks (?)
  1. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  2. using efilive to read error codes?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2008, 08:44 PM
  3. error read out useing a paper clip. HOW???
    By xx1600xx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2008, 03:47 PM
  4. Problems with VT Statesman. Don't know how to read error codes.
    By akb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2005, 09:57 PM
  5. How to show and read error codes vs II
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 08:32 PM
Tags for this Thread
