Results 1 to 11 of 11
Thread: vt airbag light stuck on
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    Default vt airbag light stuck on
    hi all im trying to sell a vt acclaim wagon a lady come and took it for a drive today and just my luck the airbag light lit up it has never done this before is this going to be an easy fix or a big problem.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The only way to reset it is with a Tech 2, so you will have to take it to Holden or someone with the right equipment. The light will come back on if there is a problem. Did this happen out of the blue or after you did some work on it?
    MY RIDE
    VT 2
    Nov 2008
    Check the cables that link your seats into the wiring harness. A loose connection there will show up as an airbag warning because of the seat mounted side impact air bags.
    vz s pack ute
    Nov 2008
    it was out of the blue i havn't worked on it in a while. ill check the cable but thanks heaps guys it couldn't have happened at a worse time :b
    VX SS S2 5.7
    May 2009
    vz s pack ute
    Nov 2008
    no not since iv owned it it has had some scrapes (not me) but nothing major. i just checked under the drivers seat wouldn't go off also disconnected the battery and re connected it. should i check the passanger side seat too
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The light won't reset even if you've found the problem. There is only one way as I mentioned earlier.
    MY RIDE
    vz s pack ute
    Nov 2008
    vx s pack II
    Jan 2010
    aLKIDA
    You need to erase the fault with a diagnostic tool.
    At Holden or a private workshop. auto-elec shop should have a diagnostic machine.
    check the plugs under the seats like the others have said.
    vz s pack ute
    Nov 2008
    vz s pack ute
    Nov 2008
    the final outcome was something in the steering wheel had a falt so 120 big ones and its all good and she bought it
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Airbag Light
    By 50LTRv8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2009, 05:02 PM
  3. VT airbag light????
    By totality in forum Electrical Wiring / Questions
    Last Post: 01-10-2006, 10:47 PM
  4. airbag light
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 01:29 PM
  5. airbag light
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2005, 04:45 PM
