Results 1 to 6 of 6
Thread: VT 5.0ltr Berlina Wagon wont start
    VT 5.0ltr Wagon
    Nov 2009
    Default VT 5.0ltr Berlina Wagon wont start
    Hey everyone.
    I drove my wagon down to the deli yesterday turned the car off, came back bout 5 mins later turned the key and "click". I can hear the starter motor click but wont turnover. i have had the starter motor checked and it is fine, my alternator and battery was changed last month. all the dash lights, stereo, electric antenna work but car wont start. it is only one click and nothing else.
    any ideas?
    cheers.
    VY S pack & VP ute
    Jun 2008
    try wiggling the battery terminals, there may not be enough contact alowing only a small amount of current draw (stereo ect..) but not enough to crank the moter over. happened to me once.
    otherwise just try a jump start, sounds more of a battery related problem tho
    VT 5.0 auto
    Nov 2008
    i have a vt 5.0 had a similar problem, in fact the same problem
    i removed the battery from the equation because it was < 1 yr old, as is my alternator
    it ended up being a faulty battery, but according to the auto elec, one of the terminals (on the car not the battery) was very dodgy & not getting enough current to the battery which over time stuffed the battery
    luckily they did it as warranty and he replaced the terminal for me ($100).
    take it to an auto elec they shouldnt charge to diag the problem & you cn go from there
    06vzcalais is offline Donating Member
    Aug 2009
    wiggle the battery terminals or while turning it over get someone to do the ol bash the starter motor trick
    VT 5.0ltr Wagon
    Nov 2009
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by leviathan_333 View Post
    Hey everyone.
    any ideas?
    cheers.
    Check the starter motor solenoid trigger wire. (violet/white)
    check if the connection on there make sure its not loose.
    And clean all the battery terminal with a wire brush.
    Can be your solenoid to on the starter motor.
  1. VX Berlina wont start
    By secret_id in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2009, 12:04 PM
  2. vz 05 wagon wont start
    By zigzagman in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-02-2009, 09:37 PM
  3. 5 spd 91 VN wagon cranks & wont start
    By lldeanll in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-09-2007, 11:52 PM
  4. VS Wagon wont start when hot
    By sholly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 12:42 PM
