Well the first question is when i was driving the light with the motor and the lightning strike came on underneath the temperature gauge, then i stoped and turned the motor of then a few minutes later turned it back on then it stayed off,
then when i opened the radiator all the green coolant leaked out from underneath the car were the coolant tube is, would that just be a big leak in the tube?
And anyone know how much it would cost to get a new one?
wtf is a coolant tube ??
If its got Wheels or Boobs its gonna cost ya money
X2!! ide like to know this!!wtf is a coolant tube ??
Haha i dunno what it's called, the tube with the yellow cap in the bottom right corner, and i have a VT commodore.
can u undo the cap?? does it look like a wing nut??
im not familar with the vt.
tighten it a little bit, or take it out and put a new oring on it??
Don't think anyone knows what i mean, well when i put water in the radiator i did it up then undid it and when i unscrewed it all the coolant come out from underneath the car, so there is a leak somewhere in the coolant tube, the one with the yellow cap.
English PLEASE??
I am totally guessing here but do you mean the overflow bottle on the right side inner guard? There are 2 hoses which go into that bottle. One is connected to the radiator filler neck and the other is the overflow hose which goes down to the chassis rail through a hole and allows excess coolant to fall onto the ground. If you put too much coolant into the overflow bottle it will spew the excess out onto the ground...
correct , im guessing he has over filled it , never undo the radiator cap when the motor is hot in case you didnt know , wait till its been sitting for ages then top up the radiator and fill up the overflo bottle till you get to the marks on the dipstick
